Please Help with I.D. of Jaguar Rear Suspension
Old Jun 10, 2012 | 10:34 PM
1rad55's Avatar
Default Please Help with I.D. of Jaguar Rear Suspension
I just recently purchased a 32 Ford with an independent rear jag suspension. I need to determine model/year range of this unit! It has a bottom drain plug - Salisbury not a Dana) and is 56" in width (hub flange to hub flange), 5 lug hubs (4.75"). The tag on the rear cover is 13/46 (3.54) gear ratio.
There are some casting numbers on bottom of diff. of which I can read most of the numbers/letters as they are worn..... C4HU-004-X5. The second zero and the X are guesses! I would appreciate any assistance with suggestions on what model/year range this suspension is that's in my street rod. There is excessive plat in the flange on the hubs and the diff. leaks pretty bad so it needs some repairs.
I'm enclosing some pictures to help with the I.D.
Thanks,
Chuck
Charlotte, NC
Attached Thumbnails Please Help with I.D. of Jaguar Rear Suspension-jag-susp.jpg   Please Help with I.D. of Jaguar Rear Suspension-jag-rear-5.jpg
Old Jun 11, 2012 | 08:28 PM
Lumppy47's Avatar
It looks to be from an e type (they also used them in xj6 up to 1987,and i believe the xjs also) this was a very common rear end for rods in the 70s-80s
BrentGardner
29
Dec 16, 2024 12:13 AM
Paradigm
Jun 15, 2019 05:59 AM
Fraser Mitchell
Oct 1, 2015 04:06 AM
ogorir
US Southwest
Sep 1, 2015 10:05 AM
dpappyp
Aug 27, 2015 06:31 AM
