problem aquiring signal to sirius radio
Old Oct 12, 2009 | 08:47 PM
MDJag's Avatar
Default problem aquiring signal to sirius radio
went to activate sirius radio in the jag tonight and the sirius radio is stuck aquiring signal. anyone else had this problem or know solution to resolve this?
Old Nov 6, 2009 | 01:16 PM
Teck4Jag's Avatar
do you have a bluetooth phone on when this happens?
Old Nov 7, 2009 | 11:25 AM
FactoryJaguarTech's Avatar
What type of satellite radio? Is it in the ashtray?
Old Nov 7, 2009 | 07:09 PM
MDJag's Avatar
yes i have bluetooth enabled and turned my phone off and still not able to get a signal. it is installed where the ashtray would be.
Old Nov 7, 2009 | 07:10 PM
MDJag's Avatar
it is a sirius radio...
Old Nov 8, 2009 | 12:26 AM
bulldoze's Avatar
Try a "hard reset", disconnect both the positive and negative battery cables and touch them together. Reconnect and try again.
Old Nov 8, 2009 | 08:37 AM
If the antenna is on the trunk lid, possible the cable is pinched. If was port installed sirius, the module should be in the trunk, right side behind the carpet. If you have access to another antenna, plug it in and see if acquires signal. Vehicle also has to be outside as Sirius signal sucks.
philwarner
Oct 4, 2024 01:37 PM
mbergen
Oct 23, 2019 10:26 PM
jdzubas
Oct 4, 2015 09:14 AM
jehart49
Sep 12, 2015 05:36 PM
jaguarbill
Sep 5, 2015 11:43 AM
