Rust proofing
Old Oct 11, 2013 | 01:43 AM
Per's Avatar
Per
Default Rust proofing
As my first Beta (Saloon) rusted quite a bit despite being rustproofed since new I thought that I would add some experience on oil based rust proofing. Lately I have used pure oil based proofing for my cars. Where I live (just outside Oslo) they use salt and grit on the roads. The grit acts as sand paper and the salt, well it just does what salt does during a wet winter. Even so rust seems to have been stopped in its tracs where it had begun and no new rust has shown up. Wrt our daily drivers I get them treated once a year, the classics get the treatment every second year. If you don't use your cars during the salty season every three years should do the trick. On these shores the cost is about a third of the full treatment with the traditional methods. I have seen some cars including a late 60'ies Opel which has been used continuously and treated annually all these years showing no rust at all.
Even on cars with older drying and cracking treatment the oil seems to have managed to creep in and effectively keept the water out. Old cracked treatment is worse than none because water seeps in and festers so this effect of the oil version is good news.
BTW, this year I have tried a new version: Lanolin based oil as in sheeps wool oil. Is said to be even better in resisting being washed off and hardly drips after treatment (the older oil is mineral oil and makes bad stains the first few days so parking on grass is preferable. From an environmental angle the lanolin version is better too although slightly less sheep (er, cheap ).
Old Nov 10, 2013 | 07:59 AM
paydase's Avatar
Thx for this info.
Could you please elaborate on the process you use to protect the various parts of the car (painting, spraying, ...)?
Old Nov 11, 2013 | 01:29 PM
Maninahat98's Avatar
Per, if you mean engine oil rust proofing......Lots of people say that it's not a good thing because of the chemicals etc..... however, I think it's great because you never(?) see rust on parts where there is an oil leak and the oil is on the underside......I used to hear said that there's as much billy-nonsense talked about cars as cameras and hi-fi!! LOL......or did you mean something else and I have picked up the wrong end of the stick? Allan
Old Dec 31, 2013 | 08:36 AM
Highway Star's Avatar
I had my Daimler treated with fat which had been injected hot and therefore in liquid condition into the cavities of the car. This is known as the "Mike Sanders method" (at least here in Germany), named after the man who developed the fat and the injection method.
Long term tests showed that the fat effectively protects the metal for years. It's recommended to check the neuralgic points, e.g. the sills, every three to five years (opinions vary on that point) for new rust and to repeat the treatment if necessary.
Larry-Cleveland
Feb 9, 2019 03:17 PM
Johnken
Apr 8, 2018 10:21 AM
bdboyle
Nov 6, 2015 02:07 PM
jospolice
Oct 1, 2015 07:52 AM
ChrisJay
Sep 27, 2015 09:08 AM
