SDD help on programming CFF and updating firmware for amp.
Old Nov 3, 2025 | 06:44 PM
  #41
Kebabian's Avatar
Originally Posted by enzofl2
It is not easy to program the amplifier, you need to know the car data. Do you have the old amplifier? the procedure is very long. Send me a PM.
I could use a little help with programming too...... If you have some time. I have a Range Rover Sport L494 with the 8 speaker system old AMP part number is EW93-19C164-CB (Mid8). I bought the DX23-19C164-BA and the speakers and subwoofer. I have started wiring all the speakers and tried the JLR SDD software coding process. I can't find the DX23-19C164-VA VBF file, which I believe I would need to rename to the EW93 file name. I have downloaded all the combined as-built files for the Range Rover Sport and the New Range Rover Sport, which I think should have the right files...... Thoughts?
Old Nov 4, 2025 | 07:55 AM
  #42
clubairth1's Avatar
Community Influencer
I always download ALL models when updating SDD. Why? I don't know but figured there might be some files that could be needed in the future. So far SDD has had all the files required.
Might not help but something to try. I have spent many hours with SDD downloading who knows what but it finally completed the downloads. That's another suggestion to keep running the update until nothing is left to update.
Old Nov 4, 2025 | 09:00 AM
  #43
Kebabian's Avatar
The issue I have is that the engineering part number doesn't correspond to the vbf number in this case...... Not sure how to determine which VBF number is correct. Pretty sure I have all the correct VBFs.
Old Mar 31, 2026 | 07:10 PM
  #44
saffy79's Avatar
Default Urgent help please
Originally Posted by mihaipg
Let me know which version of sdd you use. - 160
Let me know which version of premium Amp you use. CH32-19C164-BC from donor car SALLAAAG5CA644074
Let me know which original version of Highline Amp was born with the car. - BJ32-19C164-AF
Let me know the model and year of registration of the car. LR4 2012
So let's try together to reprogram the premiumamplifier firmware. Ok?
Give me time to help, because I'm inundated with work, but I will do everything I can. We hope well
I am in this situation right now I have two xj’s one which I’m selling so I decide to take the meridian amp and the acm (front) out and swap it around in my xj I’m keeping (I had already upgraded my speakers to meridian ones)
after swapping the amps and acm over now both cars there is no audio, Bluetooth, nav, phone etc..
I have a ssd v160 cracked and I’m struggling to work out how to access and modify the ccf files.. after reading this post it seems like you know what you doing?
I need to sort this asap and for your time willing to pay if you want but could you please help me out?
Il_Boros
Mar 31, 2026 09:39 PM
Delay_
Apr 11, 2021 03:20 PM
Baziran
F-Pace (X761) / C-X17
Sep 14, 2017 04:14 AM
R-Sport
UK & Eire
Nov 17, 2015 08:33 AM
Paors
Dec 17, 2012 10:48 PM
