Strange Voltage Fluctuations
Old Jul 25, 2013 | 01:52 AM
TinyDancer91991's Avatar
Default Strange Voltage Fluctuations
Hello, I'm a serious do-it-yourself mechanic and always have been good with fixing my own cars and troubleshooting, however I am a Jaguar newbie and I can't seem to figure the issue with my 1997 XJ6L (X300). She has about 182k miles on her now.
So here's the problem. The car's voltage seems to dip randomly causing it to chug a bit, either at idle or at low mph. The volt gauge never reads any higher than the 13 but seems to dip dramatically to almost the half-mark between 9 and 13.
Also, at highway speed, say 70 mph, it will hold steady above 13 then drop periodically. I haven't done any voltmeter testing myself, but did have the folks at autozone hook up their tester and they said the charging system is fine, as is the battery. I'm not sure if I fully trust that assumption though, mind you.
In my mind I immediately thought a bad ground, or the voltage regulator could be shoddy, but honestly, I'm not sure what to think considering the intricacies of the esteemed Jag. Ha! I'm also pretty certain the car wasn't well cared for prior to us owning it if that assists any theories.
Any advice would be greatly appreciated!!
Old Jul 25, 2013 | 02:10 AM
jimbov8's Avatar
I would take a set of voltage readings yourself. It could be the voltage regulator or loose connections. Worth checking either way.
Old Jul 25, 2013 | 06:49 AM
Thermo's Avatar
Veteran: Navy
Adam, there is a wire that runs from the computer to the alternator. THis is known as the field wire. The voltage going through this wire excites the field, which then allows the alternator to create electricity. If this wire is broken inside the insulation, it will make and break, causing the field to come and go, therefore your alternator to jump around. The other option for this is the cable running between the alternator and the battery. Again, if this wire is corroded, it can be weak and have broken inside the insulation. But, where the common weak points are, you would need to talk to people that are more familiar with your particular year car.
Old Jul 25, 2013 | 08:07 AM
Doug's Avatar
Well, since it's a random problem, the testing probably wouldn't reveal much unless it took place *while* the random problem was occuring
True on the regulator. And just recently a poorly grounded alternator caused problems for someone here on the forum.
I agree that you'll want to check for wiring faults as mentioned.
Also, is the belt tight?
Also considered the possibilty of the balancer delaminating. That's something that has come up a number of times. I've "been there" myself.
Old Jul 26, 2013 | 01:28 AM
I'm sorry I worded it a bit wrong. The correct thing to say its it happens intermittently, not randomly. That was my fault I apologize.
And yes the belt is quite tight.
Last edited by TinyDancer91991; Jul 26, 2013 at 01:29 AM. Reason: Forgot something
Old Jul 26, 2013 | 01:31 AM
Interesting! I'll be sure to try and find what you're talking about. It sounds like that field wire may be the culprit, at least i would imagine the symptoms would be similar to what's going on with our Jag.
Old Jul 26, 2013 | 06:58 AM
Doug's Avatar
No apology needed. And, whether random or intermittant, a test made while everything is working normally is likely to show nothing except....everything working normally
LnrB
Oct 13, 2015 12:45 AM
NathanDD6
Oct 6, 2015 11:20 AM
10 XF Premium
Oct 2, 2015 09:22 PM
oldjaglover
Sep 29, 2015 03:27 PM
