Supercharged engine Dimensions
Old Nov 29, 2012 | 01:17 PM
marky68's Avatar
Default Supercharged engine Dimensions
Can anyone share a link or provide me with some overall dimensions for the supercharged AJ28 engine if possible please.
I have an intended project which will be shared on here in the fourth coming months using one ...
Old Dec 1, 2012 | 10:33 PM
xjrguy's Avatar
I don't have any dimensions for these engines, but the AJ28 is the only version of the V8 that DID NOT have a supercharged version. The AJ28 was the 4.0L engine in the first generation S-Type that shared the PTEC engine management with the V6 in that car.
If I were going to use one of the V8's in a project, I would choose the AJ33/AJ34 4.2L version. Then you can pick super or non-super.
Good luck!
Old Dec 2, 2012 | 10:42 AM
marky68's Avatar
Hi Thanks, yes I should have listed the right engine. It will likely be the AJ33 4.2 fitted into the S Types I believe.
The AJ34 was fitted in the XKR's is that correct? I also understand that the AJ34 may have electronic VVT which I'm trying to avoid..
Old Dec 2, 2012 | 12:35 PM
xjrguy's Avatar
Yes, the AJ34 was fitted to the X100/X103/X105 XK8 body; the AJ33 was for the sedans. The only super not fitted with VVT though, was the '98-'99 AJ26 version. The AJ26 had an on/off VVT and the AJ27's and later have an infinitely variable VVT.
Cheers,
D.K
Dec 10, 2023 02:05 AM
cissdm
May 3, 2016 06:02 AM
FeralJag
Jan 11, 2016 05:07 PM
nd143
Sep 3, 2015 04:42 PM
OkieTim
Sep 2, 2015 12:48 PM
