Technical Mongoose Help
I am very much used to the BMW system. Go to the module and click update or reflash etc.
I am running IDS v131 which I purchased and then a mongoose cable. It works fine, reads the modules etc etc.
My only issue is how the hell do you do updates? I can't find my way into a specific module to reflash or update? Like the transmission software or the touch screen.
I'm not sure if it's a case of it's so simple I'm not seeing it or if it is that complicated!
First of all, the system behaves differently depending on vehicle year. So ... what model and year?
Note to those coming later, the OP is UK based so his model year will be one year ahead of US convention.
Nope, gone through them all.
I did find one referencing campaigns for updates but to no avail :S
Tools and applications are offered up in the interface based on their relevance to the symptoms selected. For instance, selecting Pwr Seat symptoms will not have tools for TPMS problems displayed generally.
Campaigns or bulletins will also have guides as to what symptoms to select to have the referenced update application displayed in the Recommendations Tab.
Cheers,
trosty
26
Dec 18, 2022 06:40 PM
