trouble finding a short - RESOLVED
Old Sep 7, 2018 | 03:47 PM
BillDJohnson's Avatar
Unhappy trouble finding a short - RESOLVED
Hi. I'm not a electrical expert for sure, but I know enough to keep myself out of trouble...however, I'm having a hard time finding what is drawing a constant 1.2 amps of current in my 1999 XJ8 (I posted here because I doubt it's specific to that model).
Here's what I've done - disconnected the negative cable on the battery put a multimeter between the post and the cable - measures 1.2 amps. The doors are latched and the trunk is latched. Everything is turned off.
Then, I connected a test light and started pulling fuses one at a time. I pulled every fuse and nothing caused the light to go out. Correction - I pulled every fuse except for the 3 - 5 that have special covers.
Is there any unfused circuits that could be causing the draw? Any other tests I could do?
Old Sep 7, 2018 | 04:58 PM
Couldn't figure out how to delete this thread. Turns out one of the doors wasn't latched as I originally thought...though I'm not sure why pulling the door switch fuses wouldn't have dropped the amps.
Old Sep 8, 2018 | 03:37 AM
Bill,
Members can'r delete thread - only Moderators can do this.
Good to hear you traced and fixed the fault. Thanks for coming back to post the result. I've added "RESOLVED" to your thread title.
cyber3d
Sep 7, 2017 01:48 AM
davep84
Jul 21, 2017 11:27 AM
etaent
Jul 25, 2013 11:04 AM
aceofspade215
Aug 12, 2012 11:59 AM
