Will a borescope let me see the chain tensioners?
Old Oct 26, 2015 | 07:08 PM
cyber3d's Avatar
Default Will a borescope let me see the chain tensioners?
I have a 4.0L AJ engine. Can a borescope view the tensioner to see if it is plastic or metal? I mean is there a pathway I can put a borescope in to see them?
Trying to find a way to inspect and not have to take the valve cover off.
Old Nov 7, 2015 | 12:14 PM
GGabriel's Avatar
... [is there a pathway I can put a borescope in to see them? ]
Great question! I forgot how small camera scopes are now. Check to see photos of a head with the valve cover removed. Maybe that will give the answer.
Old Nov 7, 2015 | 01:21 PM
cyber3d's Avatar
We'll see soon as I just received my smartphone Borescope! Party today - car tomorrow.
Here is a link to Amazon:
Amazon.com : YesGoShop 1M 6 LED MICRO Android USB Waterproof Endoscope Borescope Snake Inspection Video Camera 7.0mm : Camera & Photo Amazon.com : YesGoShop 1M 6 LED MICRO Android USB Waterproof Endoscope Borescope Snake Inspection Video Camera 7.0mm : Camera & Photo
Old Nov 7, 2015 | 01:29 PM
Without removing the Cam Cover, the only point of entry is the breather outlet (arrowed in red):
Will a borescope let me see the chain tensioners?-03a-cam-cover-coil-cover-removed.jpg
Problem is the Cam Cover has a baffle beneath this:
Will a borescope let me see the chain tensioners?-06-cam-cover-new-seals.jpg
Even if this wasn't in the way, there's a lot to work around to get to the tensioners:
Will a borescope let me see the chain tensioners?-04-cam-cover-cam-cover-removed.jpg
Old Nov 7, 2015 | 05:43 PM
cyber3d's Avatar
This is interesting. So, I guess you're right, the borescope can't quite make it all the way. At least from the oil filler cap. But, WHAT THE HECK is this? Can I assume this is some sort of baffling? And it IS baffling!
Old Nov 8, 2015 | 02:33 AM
ccfulton's Avatar
I believe the breather is supposed to have some metal mesh behind the baffle to condense some (most?) or the oil mist.
Perhaps the oil filler has something similar? I've never looked.
Old Nov 8, 2015 | 03:00 AM
+1
I've always understood that's why mesh is included - supposedly to reduce the amount of vaporised oil drawn into the inlet through the breather piping.
Old Nov 20, 2015 | 01:40 AM
Teck4Jag's Avatar
you need to remove the Cam covers and you can get a good look and both primary and secondary ..
good luck,i may have a set of cm cover gaskets if you do decide to remove and look
Old Nov 21, 2015 | 02:23 PM
cyber3d's Avatar
I might take you up on that offer. It will be the first time working on the engine for me. I'll PM you.
Bill Swift
Apr 11, 2018 04:08 AM
bigdhenderson
Oct 31, 2015 09:22 PM
drinkycrow
Oct 28, 2015 08:49 PM
Lubrication
Oct 27, 2015 10:16 PM
heflirob
Oct 21, 2015 06:39 PM
