Xj8L JAGUAR 2005
Old Sep 19, 2018 | 10:23 AM
Ronald55's Avatar
Default Windscreen Reservoir
What happens when a person put anti freeze in the windscreen resvoir of a 2005 xj8L
Old Sep 19, 2018 | 10:32 AM
Welcome to the forum Ronald55,
It won't harm the screenwash system but it could damage the vehicle paintwork. Flush it out with clean water and then refill with screenwash fluid.
Old Sep 19, 2018 | 10:42 AM
Ronald55's Avatar
Default Xj8L JAGUAR 2005
What happen of antifreeze os poured into the windscreen resvoir??
Old Sep 19, 2018 | 10:47 AM
NBCat's Avatar
Siphon it out, then rinse the tank with water and clear the lines to the sprayers. If coolant has been sprayed on the windscreen and the wipers used, the windscreen should be thoroughly cleaned and the wiper blades replaced. Clean any coolant from painted surfaces as well.
Old Sep 19, 2018 | 12:29 PM
Ronald55,
I have DELETED one of your posts with the same question and MERGED two others.
Do NOT multiple post the same question.
Rickkk
Jul 20, 2016 08:49 PM
Koranco
Dec 28, 2015 08:37 PM
Koranco
Dec 25, 2014 07:49 PM
Rickkk
20
Mar 31, 2014 04:36 PM
Dippnsidwayz
Jul 25, 2011 05:20 PM
