XJR v Standard Engine: 2003 & 2004
Old May 6, 2013 | 02:46 PM
MarcusJames's Avatar
Default XJR v Standard Engine: 2003 & 2004
Is the XJR Engine built "That much better" than the stadard V8?
I understand that it is super charged and puts out more torque and Hp. But I "assumed" that meant a different head configuration but the same guts inside.
Old Jun 16, 2013 | 02:23 PM
Jhartz's Avatar
Compression ratio is lower on the blown unit.
Old Jun 16, 2013 | 02:37 PM
plums's Avatar
On at least the 4.2L version, only the SC versions have under piston oil squirters.
The heads are the same. The compression difference is in the piston dome. There are also materials differences in the pistons depending on model.
Donzi
Oct 18, 2018 12:26 AM
metalmarty
Sep 11, 2015 07:05 AM
fingers
Sep 8, 2015 03:54 PM
aarahim
Sep 7, 2015 03:12 AM
