I-Pace EV 2018 - Onwards
I-Pace SIM card
Old Jan 3, 2019 | 08:36 AM
mjsammon's Avatar
Default I-Pace SIM card
I asked my dealer this question but they didn't know.
Is the I-Pace required to use data services from AT&T Wireless?
My mobile service is using Google Fi and I would like to swap SIM cards when my 3 month free period ends with AT&T.
Old Jan 31, 2019 | 06:25 AM
mjsammon's Avatar
I can now answer my own question.
I ordered a Google Fi data only SIM (took 2 weeks to arrive) and inserted it into the center console slot. Google Fi ships nano SIM cards so you'll need an adapter from nano to micro.
The card was recognized as Google Fi. To test data I opened the browser but got an error message from T-Mobile (they're the data carrier for Fi).
Contacted Google Fi support but in the end they said I was on my own because they only support a limited number of devices for data SIMs.
Digging a little deeper I found out that you have to set the APN to 'h2g2'. There was no setting for APN in the display menus so I turned off Auto select and entered h2g2 in the network field.
Voila! I'm getting data at 4G speeds (as opposed to 3G from AT&T).
Old Jan 31, 2019 | 01:28 PM
enderle's Avatar
You saved me some trouble, thanks! Good use of Google Fi. Nicely done!
Old Jan 31, 2019 | 06:38 PM
mjsammon's Avatar
Thanks Rob.
As a former Bell Labs scientist, I never let a technical problem go unchallenged.
Old Jan 31, 2019 | 07:39 PM
enderle's Avatar
I just tried to buy a Google Fi SIM and it continues to want me to also buy a phone. How'd you get the SIM without the phone?
Old Jan 31, 2019 | 09:54 PM
mjsammon's Avatar
You need to have Google Fi as your wireless provider on your mobile.
Only Fi customers can purchase their data SIM cards.
I switched from AT&T wireless last year and haven't looked back.
EDIT: your mobile phone must be compatible with Google Fi. https://fi.google.com/compatibility
Old Jan 31, 2019 | 10:34 PM
alphanstein's Avatar
Yep, Fi requires a master phone plan, then you can add up to 9 data only lines. There is this option that might work, albeit I have not tried it, just was perusing for some of the cheapest plans. It is $15/month for 3 months, so $45 to try, then you can lock in at $15 or month paid in advance for 12 months after, or it reverts to $25/month if paid monthly. https://www.mintmobile.com/product/0...sim-card-plan/
Old Feb 1, 2019 | 05:11 AM
Kingsway's Avatar
Do you need a SIM card for OTA software updates? I have a very good WiFi signal on my driveway/garage but don't want to necessarily purchase a separate data plan/SIM card.
Old Feb 1, 2019 | 12:27 PM
enderle's Avatar
They appear to be using a typical modem implementation which will favor Wi-Fi when available.
Old Feb 1, 2019 | 01:10 PM
enderle's Avatar
Default Ordered
I ordered one, will post on what the result is. Thanks (was looking at this earlier and your post made me pull the trigger)
Old Feb 8, 2019 | 02:07 PM
kolars's Avatar
I'm curious to hear how the Mint experiment goes.
When my AT&T data trial ended I noticed the "3G" icon had changed to "4G." Not sure exactly when that happened because I wouldn't have had cause to look at it often before then. I was pretty disappointed with the choice of 3G on such a car so I just ignored it and figured I'd not renew after the trial (I usually use Car Play for Google Maps, anyway, and the InControl Remote still works without a subscribed data plan). But, after a couple days staring at the 4G icon wondering, I bought a 1-month data plan from AT&T. I ran a few speed tests in the browser on the car and registered ~11Mbps down and ~10Mbps up; I hooked up my phone to the hotspot and ran a few speed tests, similar results, meaning it is pulling LTE. So, is the trial period just limited to 3G (a really bad, illogical idea), or was there an OTA software update in late January that enabled the LTE radio in the car (I don't think it was the center console fix update in late Dec . . . ?), or was it 4G all along but the icon just changed with an update (I didn't bother to test it when it said "3G")?
Old Feb 9, 2019 | 09:14 PM
enderle's Avatar
My trial hasn't ended and the display says 4G. (My free time ends next month, I have the Mint SIM and will put it in when my time gets closer (don't want to start the clock on the Mint SIM until I need to).
Old Feb 12, 2019 | 07:59 AM
Encore Specialist's Avatar
Lightbulb
So with any Jaguar, you have 5 years of "Mobile Data" included and the SIM card provided is needed to take advantage of this included wholesale data. The mobile data is used to make sure your Navigation works as designed with features such as Real-time Traffic, Gas Prices, Street View, Sharing Place & ETA, Charge Point Locations, and Route Planner App.
The 3-month or 3 GB's (whichever comes first) complimentary subscription is only for Hotspot, Live, and Web Browser. If you call AT&T they will tell you very quickly you need the data to make navigation connected features work. THIS IS NOT TRUE! And most of us have a hotspot already included on our cellphone unlimited plans.
You only need to switch SIMs after 5 yrs on your Jaguar and 4 years on your Range Rover. I can also check your expiration date. PM.
Old Mar 10, 2019 | 12:38 PM
enderle's Avatar
Default Mint works fine.
Mint SIM is in, no setting changes, and it appears to be working fine. Using the in car hotspot for this post.
Old Mar 11, 2019 | 09:46 AM
So on a Jaguar, the SIM card is good for 5 years! On a Range Rover, 4 years. The Jag SIM gives your Navigation connectivity such as Real-time Traffic, Gas Prices, Street View, Sharing, and Route Planner App. If you go to your InControl App and under settings, you will see the expiration date of your connectivity. AT&T Connect i is for Hotspot, Live, and Browser and comes with 3 months or 3GB of complimentary subscription from the date of purchase.
Old Aug 15, 2019 | 02:41 AM
I had the Mint mobile SIM in for a month or so and it kept toggling on/off to get the data and then would only go to 3G most of the time. Then I recalled this thread about changing the settings which above was related to Google Fi. Turns out that similar applies for the Mint SIM, I followed the instructions I found here and used the "alpha" name for the setting instead of auto select, now it comes on to 4G. Will have to keep a watch and see if it sticks.
https://community.mintmobile.com/you...pn-settings-27
Old Aug 17, 2019 | 11:06 PM
enderle's Avatar
I was noticing the same thing and just did the deal with AT&T, your way was a ton better thanks for posting!
Old Oct 4, 2022 | 12:28 PM
Don-Eyre's Avatar
where is the SIM actually located?
Old Oct 5, 2022 | 11:58 AM
enderle's Avatar
It is in the cubby between the seats between the USB ports and the 12volt power socket facing the back of the car.
Old Oct 6, 2022 | 04:11 AM
Don-Eyre's Avatar
Thanks. Mine is the international model. The SIM is not there or if it is, it's hidden by the upholstery of the cubby.
