Jaguar Engines & transmissions Discuss performance / modifications / upgrades etc here..
EGR impact on the air-fuel ratio (AJ33S)
Old Feb 1, 2025 | 03:55 PM
SteFn000514's Avatar
Default EGR impact on the air-fuel ratio (AJ33S)
I know, this is a complex question, and probably only the engineers who developed the engine can give me a precise answer, but I'll ask anyway:
In AJ33S 4.2 S/C engines (without VVT), does the ECU take into account the amount of recirculated exhaust gas from the EGR valve when calculating the air-fuel mixture?
I mean, the EGR system recirculates exhaust gases into the intake, replacing part of the fresh air. As a result, the amount of oxygen reaching the engine is lower, so the fuel quantity should be adjusted (reduced) to maintain an optimal air-fuel ratio.
Is the Denso ECU capable of compensating for this oxygen reduction caused by the EGR and adjusting the fuel accordingly?
Theoretically, it should be, but I actually hope the system is too outdated to do so. Because if the ECU does account for the EGR, physically bypassing it could be a bad idea, and an electronic intervention might be necessary - which is very difficult and certainly expensive on our cars.
On the other hand, if the EGR system isn't factored in by the ECU, disabling it should be much easier.
I'm open to any ideas!
Old Feb 4, 2025 | 07:17 PM
MrDeBruce's Avatar
I have a 2002 S-Type R and I blanked off the EGR valve (but not disconnected the valve itself). This means it activates but flows no air. The ECU can detect this and throws on the MIL light, so the ECU does detect the impact of the extra gasses from the EGR and notices when it's not there.
Old Feb 6, 2025 | 10:55 AM
Just Me's Avatar
"does the ECU take into account the amount of recirculated exhaust gas from the EGR valve when calculating the air-fuel mixture?"
Yes in both the map and with the O2 sensor
Old Feb 6, 2025 | 10:58 AM
Just Me's Avatar
"blanked off the EGR valve (but not disconnected the valve itself). This means it activates but flows no air. The ECU can detect this and throws on the MIL light, so the ECU does detect the impact of the extra gasses from the EGR and notices when it's not there"
The intake air flow sensor will see a reduction in flow when the EGR opens. Generally, it just compares that to the EGR position sensor map.
5speedusa
Jul 30, 2025 12:11 PM
super_jag
59
May 10, 2022 12:28 AM
SteveM
Jun 25, 2015 09:02 AM
Garywrx
Feb 13, 2015 12:06 PM
Krajcok
Jul 29, 2014 05:13 PM
