Jaguar Engines & transmissions Discuss performance / modifications / upgrades etc here..
Installing the electrical for the alcohol injection- which is sensor output wire?
Old Jun 24, 2012 | 03:01 PM
WaterDragon's Avatar
Default Installing the electrical for the alcohol injection- which is sensor output wire?
Which wire on the mass air is the MAF sensor signal output wire.
I see White, black, orange, green, another black...
eeny minee miney puff,
I dont want to pick the wrong one and let the smoke out.
I hear when you let the smoke out of electronic devices, they no longer work...apparently they need the smoke
Old Jun 24, 2012 | 04:03 PM
Jeff0296's Avatar
On which model car water dragon
Old Jun 24, 2012 | 04:10 PM
Jeff0296's Avatar
The smoke thing is all to true
Old Jun 24, 2012 | 04:22 PM
Jeff0296's Avatar
It's the green/ white
Here is the elec PDF
http://www.jagrepair.com/images/Auto.../jagxj2002.pdf
Regards
Jeff
Old Jun 24, 2012 | 04:24 PM
Jeff0296's Avatar
Info you need is on page 54 and 55
Old Jun 24, 2012 | 04:35 PM
Thank you! "You Da Man"
I don't know where my multimeter is hiding. My wife was probably using it somewhere, but I can't find it, so I'd thought I would ask on the board rather than borrow one from a neighbor,...so, thank you for saving me the trip
And "Jeff" is a name reserved only for the coolest of cats
2002 XJR (I've done this twice today-forgetting to list the car/year)
Old Jun 24, 2012 | 04:43 PM
Regards
Jeff
Unfortunately, that PDF was translated into greek...
I looked again, I have a white with blue stripe and a solid green wire... 2002 XJR
Which wire? ( I'm picturing that scene in the Abyss )
Old Jun 24, 2012 | 04:50 PM
Jeff0296's Avatar
Looking at it two ticks
Old Jun 24, 2012 | 04:57 PM
Jeff0296's Avatar
You should have 5 wires
black with white stripe on pin 2
Green with white stripe on pin 3 this is the signal wire
White with blue stripe on pin 1
Black with green stripe on pin 5
The stripe bead colour is pretty thin and may be on the underside of the wires
Orange on pin 4
Old Jun 24, 2012 | 04:58 PM
Orange on pin 4
Ok, just to verify, the sensor output is the Orange wire on Pin 4?
Old Jun 24, 2012 | 05:05 PM
Jeff0296's Avatar
Orange is IATS signal
Green with white bead is MAFS signal
Regards
Old Jun 24, 2012 | 05:07 PM
Regards
OK, I'll be using the Green wire then.
Thank you very very much (I thanked you twice in this thread)
Let's get this party started!
Old Jun 24, 2012 | 05:09 PM
Jeff0296's Avatar
Forcedair1
Sep 8, 2025 01:57 PM
dsnyder586
Dec 29, 2024 07:39 PM
mbergen
Oct 23, 2019 10:26 PM
KarimPA
Sep 12, 2015 08:15 AM
mcdutch
Sep 4, 2015 03:38 AM
