Jaguar Engines & transmissions Discuss performance / modifications / upgrades etc here..
Kenne Bell boost-a-pumps for XJRs
Old Dec 11, 2012 | 10:37 PM
WaterDragon's Avatar
Default Kenne Bell boost-a-pumps for XJRs
If anyone is going the route of adding fuel capacity via the Boost-a-pump, the correct unit is KB89064 which is the true "dual" unit. It is the more expensive one $459 list and the one that is usually used on the Ford Mustang GT500
thought I would just post here to save others the trouble of getting the wrong one initially like I did...
Old Dec 12, 2012 | 12:04 AM
avos's Avatar
Reason is that when upping the voltage you increase the amp usage, and on our cars you would be getting close to 20 amps then (pending the voltage/pressure you choose). As the single BAP unit is rated 20amps, it’s safer to get the dual unit which is rated 40amps.
Old Dec 12, 2012 | 12:28 AM
plums's Avatar
Upping the voltage is a means of overcoming voltage drop due to deficient wiring or a means of spinning the pump faster. If it is a case of excessive voltage drop, then increasing the wire gauge would be sufficient. For 20 amps, no less than #12 gauge on each power and ground lead. Of course, this is ideally all the way to the pump connectors so it would involve fabricating new link leads for the inside tank connections.
Old Dec 12, 2012 | 12:40 AM
avos's Avatar
A single stock pump consumes only about 8 amps, so it’s not so much about voltage drops, but when upping the voltage/pressure the pumps could consume about 2 amps more, so the stock wiring is still sufficient for that.
Old Dec 12, 2012 | 01:39 AM
plums's Avatar
According to one reference chart, a 10 foot complete round trip circuit (power + ground) needs #14 AWG at 10A to limit voltage drop to 3 percent. It would be #16 AWG for 10 percent.
If we are generous and say that the existing wiring is #16 AWG, and that the relay is seeing 14.0v, then the pump is experiencing 14.0v-1.4v=12.6v
At #14 AWG, it would be 14.0v-0.42v=13.58v
At #12 AWG, the drop would be nominal for 10 amps.
Old Dec 12, 2012 | 02:19 AM
avos's Avatar
Electrics isn't my area, and although there are losses as you say, you need to up the voltage much more than you can recover by installing different wiring to cover for the losses (although as said, it depends on the pressure/flow you require). I wouldn't just put the BAP to the maximum 17.5 voltage either; set it to a voltage that sufficient for what you need.
PS I just installed a BAP, and iirc the outside tank wiring seems much thicker than a 16awg, would guess more a 14awg.
Old Dec 12, 2012 | 02:21 AM
XJR-99's Avatar
Kenne Bell says:
" When do I need to look at wiring size?
When installing any larger/higher amperage than stock fuel pump(s). Any pump that produces more fuel will use more (amps) and tax the stock wiring. The BOOST-A-PUMP is designed to work with stock wiring. Only a larger fuse is necessary. "
Old Dec 13, 2012 | 05:54 PM
ronbros's Avatar
been there done that and blew up some nice engines!
now, when i'm considering a hi-boost engine and fuel system, i use a 10ga. wire run directly from the battery, and a 50amp relay, thats uses the factory wiring to activate the relay. no more hi-boost F/P drop, with data recording.
you could wire in the circuit with a BAP without any problems.
ever considered a rising rate FPR alsop
Old Dec 13, 2012 | 06:00 PM
ronbros's Avatar
of course you have a proper digital A/F ratio gage with data logging?
if your gonna go for it,may as well do it right!
engine rebilds can get expensive.
Old Dec 15, 2012 | 01:35 PM
How did you blow up your engine with more fuel?
I am planning on adding the GT500 Boost a pump. Yes i WILL have a digital A/F gauge installed at the same time, no data logging, just a gauge.
Old Jul 14, 2013 | 11:31 AM
So this happened to you?? Please elaborate
Old Jul 28, 2013 | 11:02 AM
I'm finding there are two Dual units, no adjustment but one model 17.5 v and competition model 20V
Old Jul 28, 2013 | 12:12 PM
JgaXkr's Avatar
I think that link is for a single pump. Here is the link from Kenne Bell
Boost-A-Pump
Old Jul 29, 2013 | 02:28 PM
Yes, there are only two versions:
single pump driver with adjustable voltage and
Dual unit which comes in either 17.5 V or 20V
the ad I had linked to was using the incorrect photo
MrWhite
19
Jun 14, 2022 07:49 PM
MrWhite
Oct 1, 2015 01:43 AM
JAMES1944
Sep 29, 2015 11:58 AM
N3yyz_XJR
Sep 27, 2015 11:26 AM
moff1959
Sep 26, 2015 05:35 PM
