Jaguar Engines & transmissions Discuss performance / modifications / upgrades etc here..
Limited slip differential REVISITED
Old Mar 28, 2010 | 09:26 PM
  #81
Panthro's Avatar
See post #66 in this thread.
Old Apr 28, 2010 | 12:37 PM
  #82
super_jag's Avatar
So you are saying since my S-Type is 2003 the 06-07 XK differentials are the same. so all I need is a LSD for a 06-07 XK and everything is good?
Old May 2, 2010 | 03:23 PM
  #83
Panthro's Avatar
Jaguar changed the rear differential for the S-type starting with the 2003 models. So you should be able to swap in the differential. I was looking into doing this about a month ago & I have the part #s and stuff for this somewhere. When I find it, I'll post it up.
Old May 6, 2010 | 01:25 AM
  #84
avos's Avatar
I spoke with Tom from TL Jaguar in the UK if he would like to investigate (he also sells the quaife diffs for the aly body), the only thing he would need is a second hand unit from the Stype. Maybe if there are enough people interested he will start the investigation.
Just PM me or contact Tom directly.
Old May 10, 2010 | 07:06 PM
  #85
viscoussquirrel's Avatar
Dfwx hows that limited slip working out for ya bud?
Old May 20, 2010 | 08:17 AM
  #86
GreenJewel's Avatar
Originally Posted by Paul Pavlik
When I bought my car with 15k mi, it had a noisy differential. It was replaced under the original new car warranty. Apparently, this differential is not up to the task , especially on the XKR.
Paul what kind of noise? Did it sound like a loud vibration/hum coming from one side of the rear of the car once you hit a certain speed?
Mark
Old Jun 7, 2011 | 05:17 AM
  #87
Mountain s type's Avatar
With a first gen non supercharged so type and a lincoln rear if I swapped the gears forum say a 4.09 gearset would I need to remap my computer???
Old Jun 10, 2011 | 12:20 AM
  #88
kaine806's Avatar
Here is what I was able to find so far....
The following article is a copy of the original web page created by Mark Knight documenting his Dana 44 ring and pinion install in a Jaguar Salisbury differential.
Here's a list of parts:
Bearings and Races
Carrier Bearings: 25590
Carrier Races: 25523
Pinion Bearing Inner: 31594
Pinion Bearing Inner Race: 31520
Pinion Bearing Outer: M88040
Pinion Bearing Outer Race: M88010
I have used 2 different Auburn Gear Carriers. I currently have the 5420111 Hi-Performance for Dana 44 3.92 up, 19 spline.
The input seal is a CR 15788
Old Sep 3, 2012 | 07:05 PM
  #89
2000blackxkr's Avatar
Question xj300 dif
never mind.. i figured out my own question...
Please feel free to ignore this post!
Old Oct 14, 2017 | 10:39 AM
  #90
Aj Jackson's Avatar
Originally Posted by Jaxkr
What you need is an XJR 6 diff & front mounting plate & it is a straight drop in. You will need to modify the exhaust mounts for the overaxle pipes. The Mercedes trans is fitted to supercharged cars from 1998-2002. If your car is not supercharged you don't need to program the TCM. You can fit 3.07 3.27 3.58 3.77 or 4.09 ratios.
where can I get a different gear ratio for my 98 xj8?
Old Oct 19, 2017 | 01:59 PM
  #91
Andrey's Avatar
This might be interesting to XF, XJ, XK owners
https://www.jaguarforums.com/forum/x...5/#post1778640
hoodun
May 15, 2019 09:31 PM
Johnken
Apr 8, 2018 10:21 AM
Dave1109971
Dec 15, 2015 06:16 PM
Woznaldo
Sep 26, 2015 11:02 AM
