Jaguar Engines & transmissions Discuss performance / modifications / upgrades etc here..
Where would I find a set of head studs for my 2002 XJR
Old Nov 17, 2012 | 05:06 PM
WaterDragon's Avatar
Default Where would I find a set of head studs for my 2002 XJR
I've found a set of heads I'm going to swap onto my 2002 XJR.
Does anyone know where I would find a set of head studs to upgrade/replace the bolts with??
Old Nov 17, 2012 | 06:14 PM
The XJR takes 20 cylinder head bolts but sit down before you read the cost.
I've found the details on British Parts UK website:
They have a US based distribution centre in Houston at:
Contact Us :: British Parts International
Worth entering the part number in your search engine to check for other suppliers.
Old Nov 17, 2012 | 06:38 PM
Attachment 26252
Contact*Us*::*British*Parts*International
Thank you for the link,
Those are stock replacement bolts, I'll use those if I can't find studs, but I'm hoping I can upgrade to studs. I'll call ARP monday and see what they have to say.
Old Nov 17, 2012 | 07:47 PM
JgaXkr's Avatar
If you go with the stock head bolts it is cheaper to go to a Land Rover dealer, same part just a lot cheaper. I think if you use studs you may have to drop the engne out as clearance is an issue. What are going to use for head gaskets? When I was doing my engine Jason @ Nameless told me he had Cometic gaskets that he just wanted to get rid of.
Old Nov 17, 2012 | 08:31 PM
XJR Prototype's Avatar
Just call buckhead they used them on thunders build i think.
Old Nov 17, 2012 | 09:25 PM
Wow, I didn't think of having to drop the engine. I would rather avoid that. I was thinking studs would be stronger, which could be an advantage if I ever wanted to add some giggle gas in the future. If it does require dropping the motor, I'll take the easier route and just get the replacement bolts as I am not going to exceed 15-16 psi boost.
Thank you for the buying at land rover advice. Is it the same part number? AJ89986? The $7.69 each as listed above seems doable, do you think they could be had for less at a rover dealer?
Old Nov 17, 2012 | 09:26 PM
Will do, good advice
Old Nov 19, 2012 | 11:15 AM
I was thinking about it. The muppets tell me that arp studs generally do not require to be torqued to any specific requirement before putting the nut on, so I can drop them in with the head, and then thread them with the head in place, this way I can avoid needing to slide the head over the studs, thereby eliminating the problem of clearance requiring the block to be moved....yes??
Old Nov 19, 2012 | 12:52 PM
XJR-99's Avatar
Originally Posted by WaterDragon
I was thinking about it. The arp studs generally do not require to be torqued to any specific requirement before putting the nut on, so I can drop them in with the head, and then thread them with the head in place, this way I can avoid needing to slide the head over the studs, thereby eliminating the problem of clearance requiring the block to be moved....yes??
How about these? Cylinder Head Stud Kit for Jaguar 4.0L/4.2L
Old Nov 19, 2012 | 01:10 PM
Originally Posted by XJR-99
Muppet secret agent code named "Animal" found ARP studs for $4.88 each.
ARP studs are now ordered
Old Nov 19, 2012 | 01:48 PM
XJR-99's Avatar
Maybe Eurotoys is selling same studs, but they have " a little bit " better sales margin...
Old Nov 19, 2012 | 01:51 PM
My thoughts exactly..
How did you get into my head? HellooooooooOooo, wow, there is a lot of space in here
Old Nov 19, 2012 | 02:01 PM
Don't hide the deals man!
Old Nov 19, 2012 | 02:10 PM
I just sent the question and got a response from S.A. Animal. Apparently he cannot get them for $4.88 each, he had some credit with a place and these were $4.88 more than some other set of studs he had credit for, so he paid the difference and was passing them on to me as a trade for something I had done for him.
I thought that was ridiculously cheap, but wasn't going to argue.
So I'm just lucky to get the benefit of that one time deal it seems. So, sorry, false alarm...
Old Nov 19, 2012 | 02:12 PM
No i just wanted to bookmark the site you found them on LOL... just in case.
h4wk
Nov 27, 2015 05:10 PM
montypeek
Sep 6, 2015 04:57 PM
roumor
Aug 28, 2015 01:02 PM
Andrew McVey
16
Aug 27, 2015 07:21 PM
brent65622
Aug 26, 2015 08:41 AM
