Jaguar Forums Feedback & Suggestion Center Need help with Jaguar Forums? Ask here! Have a suggestion to help improve Jaguar Forums? Tell us here....THIS SECTION IS NOT FOR TECHNICAL QUESTIONS
Only one thumbnailed image per post?
Old Sep 26, 2012 | 11:48 PM
CleverName's Avatar
Default Only one thumbnailed image per post?
Just hit a curiosity... Reference post HERE
To avoid filling your storage, I have a hosted thumbnail image and select "Insert Image"
Then I select the thumb and link to the larger version..
Like so:
A second image done the same way does not show up in the post
Yet I see them both in my editing, and post preview... but they are not there when I submit the post...
If I log out, they are there... If I log in they are gone...
Am I making mistakes?
Thanks for your guidance
Vince
(Sure enough, the links here work fine...grrrrr)
Old Sep 27, 2012 | 04:41 AM
Cadillac's Avatar
Testing :
Old Sep 27, 2012 | 04:45 AM
Cadillac's Avatar
Hey, I edited the images in your topic please don't mind . I am gonna show you how to show the images I think http:// was the culprit
When you insert http link you should delete the http:// in the Image Insert pop up that is the blue highligted one . This is what I do because if you don't this then images don't show up
Another thing you should use the image link that you see when you click on . In your case ,your original post where it begins with A second image .....
I click on the image and see it original size .Then I left click on the link ,not the right click on the image , this is important . Use the 1st one when you wanna insert an image
2nd image is what I am talking about
Attached Thumbnails Only one thumbnailed image per post?-image-inserting.jpg   Only one thumbnailed image per post?-image-inserting2.jpg
Old Sep 27, 2012 | 10:55 PM
CleverName's Avatar
Thanks,
Looks like I need to play a bit with it....
I dislike the larger image as seen in post number 2 here... A long thread could get cumbersome loading images of that size... the thumbnail is a much cleaner and faster load.
test - thumb only via insert image
test - thumb with embedded hyperlink
test - Full Image via Insert Image
Thanks, guess all works fine but I didn't see any change I made... maybe it was the beer or two I had while trying...
Thanks for your patience....
Vince
Old Oct 15, 2012 | 10:24 AM
H20boy's Avatar
good assist caddie...eh, regent! (Still haven't got used to the name change )
1LowCat
Sep 14, 2015 07:51 PM
kstevusa
Sep 7, 2015 01:12 PM
user 652867429824
Sep 5, 2015 12:53 PM
Jaguar Forums Editor
Jaguar Press release
Sep 4, 2015 09:18 AM
nd143
Sep 3, 2015 04:42 PM
