Mark V - X 420G 1948 - 1970
Mark IX Brake Fluid Pressure?
Old Feb 10, 2015 | 04:45 PM
Jagbird1's Avatar
Default Mark IX Brake Fluid Pressure?
Does anyone know what the design was for the brake fluid pressure at the calipers for older Jags. I have a gauge and read 800 lbs max which is not stopping the car worth a hoot.
I checked the Jag service Manual and no mention of it.
Old Feb 11, 2015 | 04:31 AM
billdheller's Avatar
Jagbird, I don't know the specific pressure, but I had a 1961 MKIX and it did have a vacuum assist to boost the brake pressure. The MK IX's are a big beautiful car, an older car with four wheel disc brakes.
Old Feb 18, 2015 | 08:17 PM
mikebaker3's Avatar
There are two master cylinders. The one activated by the pedal sends fluid to the second cylinder mounted on the brake servo under the Right front seat mounted inside the frame rails.
Old Feb 21, 2015 | 03:23 PM
Fraser Mitchell's Avatar
If the brake servo isn't working, stopping the car will take longer and need a real big push ! These are very heavy cars. So you need to check out the servo.
Jandreu
Jun 30, 2022 03:10 PM
Armor6
Sep 14, 2015 07:56 PM
Richard_gib
Sep 12, 2015 07:08 PM
Armor6
Sep 10, 2015 12:08 PM
giandanielxk8
Sep 6, 2015 07:21 PM
