Mark V - X 420G 1948 - 1970
Mark X V12 Engine Swap anyone?
Old 08-22-2016, 05:34 AM
GregChap's Avatar
Question Mark X V12 Engine Swap anyone?
Hi All,
I have a 1965 Mark X project car, and a 1970 V12 engine.... interested in putting the two together but not sure about the total cost once I get started.... still in the investigation phase... keen for advice from anyone who has done something similar.
Old 08-22-2016, 09:03 PM
primaz's Avatar
I personally think that most engine swaps are never easy, even when people make kits to make it easier. When you do something not done before or at least a swap where there is no kit available then you better be highly skilled and even if you use shops or if you use a lot of your own labor, you need to not have issues with money as it will inevitably cost more than you plan.... It can be a great end result but 80% of the project cars never get done because a number of things get too difficult and usually too expensive.
Old 08-24-2016, 10:08 AM
Jagboi64's Avatar
Received 3,071 Likes on 2,039 Posts
Check the width of the engine bay. I looked at putting a V12 into A Daimler DS420, which is Mark X based and I think there was less than 1/2" clearance over the width. I would have had to remove the engine to change the air filters....
Is your 1970 V12 a European or North American spec engine? If NA, you'd get just as much power and much better fuel economy by putting in an AJ16 engine from a 1995-97 XJ6 and also using the 4 speed transmission.
Old 11-11-2016, 02:50 PM
jhkm12345's Avatar
I did it on my mk10 with a 6 liter from a 1995 xjs... it's doable, but not a simple task.
I had to remove at least 15lbs of metal from the car before it would even fit in.
I also grafted front and rear suspension to the body tub to make it stop and turn equally well as go-fast.
Mguar (10-27-2021)
Old 11-14-2016, 01:41 PM
Gijzzy's Avatar
Do you have pictures or some of a guideline how you did it? A friend of mine is starting a project like this with a 6.0 X300 V12. I have stripped an X300 to the bare necessary parts needing the car to start and drive. So that was step one of many.
Old 11-14-2016, 01:52 PM
jhkm12345's Avatar
I did a full write-up on a different board. it's a mk10 specific group and the knowledge there is on point with the big cars...
Lots and lots of cutting... I removed over 15lbs of metal from the car in order to make it fit.... also modification of the crossmember and tunnel for trans clearance.
The Jaguar Mk10 & 420G Owners Symposium
It's in member's cars listed as frankenstein mk10
The following 2 users liked this post by jhkm12345:
Doug (11-14-2016), Lagonia (11-14-2016)
jagxk2008
08-23-2016 11:25 AM
OUScooby
08-23-2016 03:03 AM
orangeblossom
08-21-2016 06:38 PM
xjfourty
08-19-2016 12:17 PM
Quick Reply: Mark X V12 Engine Swap anyone?
