Mark V - X 420G 1948 - 1970
Speedometer wandering
Old Aug 28, 2020 | 10:51 AM
dr3am's Avatar
Default Speedometer wandering
Howdy folks! Just picked up a new to me 1965 Jaguar Mark X 4.2 92000 miles! Photos attached. I'm surveying, cleaning, and testing. I'm not familiar with the mechanical speedometers, or cars of this vintage. Is a wandering speedometer due to a part failure or an indication of a need for adjustment?
Old Aug 28, 2020 | 01:30 PM
Fraser Mitchell's Avatar
A wandering speedo is normally due to lack of lubrication of the rotating cable that drives the speedometer. The car you've just bought looks absolutely immaculate so probably hasnt been used a great deal in recent times. So, time now to lube the cable. I don't think grease is used, more like engine oil and you mustn't get it too near the speedo. How to do the lube ? Take the whole cable drive off the back of the speedo, pull out the inner cable, and lube the whole length apart from about 8" near the speedo itself. The inner is like a very finely wound spring actually.
Old Aug 28, 2020 | 02:28 PM
Bob_S's Avatar
Hi DR3am,
Welcome to another Michigander!
I would use something like graphite dry lubricant available at O'Reily or Autozone.
The E-type manual I have at my finger tips recommends Esse T.S.D. 119 or equivalent grease and doesn't recommend oil. I did a quick search for "Esse T.S.D. 119" and came up empty.
Hope this helps.
Old Aug 29, 2020 | 08:32 AM
pendliss's Avatar
The speedometer can also waiver if the inner shaft of the flexible cable is not engaged fully. Make sure the end projects about 3/8".
Phil E.
1966 MK X
2002 XK8
Old Aug 29, 2020 | 10:26 AM
S-Type Owner's Avatar
This is the type of lubricant that we used back when I was in "the business"; it is specifically formulated for lubricating cables and especially speedo cables:
https://www.oreillyauto.com/detail/b...eot/403?pos=23
Old Aug 31, 2020 | 10:41 AM
dr3am's Avatar
Thanks for the warm welcome and the tips! Overall car is looking pretty solid as I tear through it but I haven't got to the speedometer yet. Every gasket is leaking (its normal for a British car right? LOL), so I'm going to go ahead and just change all the gaskets out before a failure gets to the cylinders. Good news is....aftermarket rear HVAC. Newer looking AC compressor, starter.
carzaddict
Photography
Nov 26, 2023 11:04 AM
Brian Gerber
Aug 5, 2020 11:41 AM
Harry Dredge
Feb 12, 2017 03:16 AM
oxygen
Nov 2, 2016 05:34 PM
adam699
Sep 12, 2011 11:18 AM
