1996 XJR 5 Speed Manual Getrag Complete engine with spares. RARE!
For Sale
Engine - Complete
  • Engine - Complete - 1996 XJR 5 Speed Manual Getrag Complete engine with spares. RARE! - Used - 1994 to 1997 Jaguar XJR - Gilbertsville, PA 19525, United States
    Sold
    Sold
    Sold
    Sold
  • Price
    $6,500
    • OBO
  • Location Gilbertsville, PA, 19525, USA
  • Condition Used
  • Compatibility
Make Model Year
Jaguar XJR 1994 - 1997
Description:
6500.00$ OBO$
My Project XJC has taken a turn. I came across an Aston Martin V12 with a Tremec 6 Spd!
So as crazy as it seems I need to sell My AJ16S 5sp Getrag. This Engine has 76000 Miles on it.
I have not done anything to the inside It has great even compression an develops oil pressure with just the starter no problem.
I Have. Replaced . Everything external all gaskets and had most parts powder coated or painted. all hoses are new. Clutch and fly wheel are stock. Injectors have been cleaned and flow tested. I have rewired all of the sensors with new connectors and wires to be used with aftermarket ECU(not Included). I have all of the original wiring and ECU and airflow meter. (it will need work to be used) . The engine has new custom made Exhaust manifolds that will not crack ever! The down Pipe has been converted to accept modern wide band 02 sensors. A new 1 wire low RPM high output Alternator. New AC Compressor.
Extra Parts
Complete XJR Head.
Complete Intake
Valve Cover
Starter
Alternator
I'm not a big writer I would rather correspond via Telephone so if you have questions please P.M. Me with your phone number and a time and I will call you.
The Engine is located near Philadelphia PA.
Thanks For Looking!
Russell Klein
Old Mar 3, 2019 | 07:45 AM
quartetchiang's Avatar
Hi Russell!
What Aftermarket ECU were you planning to use? What needs to be done to the factory management system for it to work?
Old Mar 3, 2019 | 12:04 PM
Rustyxjc's Avatar
I have a MS3 Gold Box all Wired in.
I have the complete wiring harness and ECU there is a man I think its XJengineer on this forum who can modify the ECU to run as a manual.
The ECU I have came with the Engine and 5 speed it may be a manual ECU I just don't know..
The wiring will stay on the engine. All of the wires are printed on them what they go to one could just splice them all to the original harness and go. I wouldn't though with today's technology one would be far better off with an after market ECU and a tuner. I have attached a pic of the ECU in case your interested.
Rusty
Old Mar 5, 2019 | 08:32 PM
Thanks Russell. Does the aftermarket ECU come with the package? Does it require a tuner familiar with MS3 Goldbox to configure it? Also, if I were to buy from you, it'll have to shipped overseas. Do you have the weight of the package? I also need your Zip to calculate shipping cost. Paul
Old Mar 5, 2019 | 09:23 PM
Rustyxjc's Avatar
Please check your PM I sent you a message.
Rusty
Old Mar 13, 2019 | 09:33 PM
Rustyxjc's Avatar
I took some more pictures. 1996 XJR 5 Speed Manual Getrag Complete engine with spares. RARE!6500.00$ OBO$
Extra Parts
Complete XJR Head.
Complete Intake
Valve Cover
Starter
Alternator
Thanks For Looking!
Russell Klein
Old Mar 14, 2019 | 03:40 AM
A question come to mind. How about prop shaft? One must be able to source a manual X306 prop shaft to work with it, right?
Old Mar 14, 2019 | 06:17 AM
Rustyxjc's Avatar
The drive shaft yoke is included look closely and you will see it. That is the impossible thing to find from there any drive shaft shop will be able to fabricate one.
Thanks for looking!
Old Apr 7, 2019 | 08:01 AM
Rustyxjc's Avatar
Hello Everyone since the weather broke I was able to get this out into daylight! I took all new pics and added pics of spares.
I Have. Replaced . Everything external all gaskets and had most parts powder coated or painted. all hoses are new. Clutch and fly wheel are stock. Injectors have been cleaned and flow tested. I have rewired all of the sensors with new connectors and wires to be used with aftermarket ECU. I have all of the original wiring and ECU and airflow meter. (it will need work to be used) . The engine has new custom made Exhaust manifolds that will not crack ever! The down Pipe has been converted to accept modern wide band 02 sensors. A new 1 wire low RPM high output Alternator. New AC Compressor.
Extra Parts
Complete XJR Head.
Complete Intake
Valve Cover
Starter
Alternator
Thanks For Looking!
Russell KleinI
!6500.00$ OBO$
Thanks For Looking!
Russell Klein
Old May 5, 2019 | 11:09 AM
64etype's Avatar
I'm new to this forum and can't see where to send you a PM. Anyway, I'm thinking about your engine/trans for a swap into my recently acquired '94 XJS? Do you know if this would be a straight forward bolt-in....assuming I could find the pedal assembly and the ECU is to the proper spec? What about if I xourced a GM automatic (the current transmission in the car is a Getrag automatic)? I know very little about the similarities between the later XJS chassis and the X300, which I'm assuming was the parent car to this engine/trans...I'm hoping you do.
If I can figure a way to PM you I'll send you my phone number...
Old May 5, 2019 | 12:40 PM
64etype's Avatar
Apparently I'm currently restricted from doing certain functions on the site because I only signed up a few hours ago. Anyway, please disregard my previous post above (which I've tried to delete). The reason is that I found a string in another section that discusses the supercharged swap into the XJS. My questions were addressed there. Sorry for the premature post.
Old May 5, 2019 | 01:42 PM
Rustyxjc's Avatar
Hi thanks for your Interest.
RGK
Old May 10, 2019 | 05:02 PM
Rustyxjc's Avatar
Hello Everyone...
Apparently there is no market for this engine. I'm ready to deal im lowering the price to 3500.00 with extra parts. and Factory auto ECU.
PM if you are interested.
Rusty
Old Jun 14, 2019 | 03:46 PM
64etype's Avatar
Originally Posted by Rustyxjc
Hello Everyone...
Rusty
Do you still have this engine and transmission?
Old Jun 14, 2019 | 07:13 PM
Rustyxjc's Avatar
Yes I do
Old Jul 30, 2019 | 02:19 PM
juha_teuvonnen's Avatar
Could you please PM me your number? Or let me know if you would like me to PM your my number. I had a couple of questions about the engine/trans. thanks.
Old Aug 3, 2019 | 01:06 PM
Rustyxjc's Avatar
Hello! Everyone! I have had interest in this engine and transmission. Interestingly some people want the transmission and some people want the engine. So I will agree to break it up ....If I can find two individuals who are interested and will commit to buying at the same time.
Each buyer will be responsible for their own shipping costs.
The Trans will come with the AJ16 Manual rear plate clutch and Flywheel.
The Engine will come with everything engine related I have includeing ECU Automatic end plate Flex-plate spare intake ect.
The threshold for the sale is 3500.00 however we get there.
Rusty
Old Aug 4, 2019 | 06:06 AM
Congrats Rusty! So you've sold both?
