1960 3.8 restarting problem.
Old Aug 13, 2020 | 06:30 PM
Mark Bialzik's Avatar
Default 1960 3.8 restarting problem.
The car starts fine when cold. When hot it takes many cranks to restart. I originally traced the problem to the coil, so I replaced it with a new Lucas coil Any ideas?
Old Aug 13, 2020 | 06:54 PM
Glyn M Ruck's Avatar
Fuel vapourisation after heat soak possible. Is your cooling system up to snuff? What is your operating temperature?
Old Aug 14, 2020 | 04:01 AM
SimonCav's Avatar
Does sound like fuel vapourisation. With engine off there's no flow in the fuel lines, so residual heat from the engine vapourises the fuel trapped in the fuel lines / carbs. It's common on many 'classics'. I bought a heat shield (fits between the engine & the carbs) for my Triumph GT6 - solved the issue nicely.
Also getting it on my 4.2ltr Mk2, but only takes a few extra cranks as it sucks the new fuel through so not a real issue (also helped by having a louvered bonnet!!!).
Old Aug 14, 2020 | 03:18 PM
David84XJ6's Avatar
Next time you come home from a good run, pop the bonnet open and check restart after 30 minutes. This solved problem on my XJ6; my XKE had louvered bonnet no issues.
Rgds
David
Gharv64
May 19, 2018 11:13 AM
redtriangle
Mar 7, 2016 07:08 AM
dstjohn
Nov 15, 2015 12:58 PM
Feb 11, 2015 02:35 PM
Jashuar85
Aug 25, 2011 11:23 AM
