1961 Mk2 3.8 Restoration
Old May 22, 2019 | 03:11 AM
  #221
MK2's Avatar
MK2
Gene,
It is hard to tell, but I think the shims in your baggie are the window frame shims that go between the top of the door and the window frame to line up the window. I assumed based on your report that your problem was the alignment of your door - not the door window frame. Scroll down a bit on this post from my website and you will see the door hinge shims to which I was referring. Doors and Windows ? Valve Chatter
Lin
Old May 22, 2019 | 09:12 AM
  #222
gene61jag's Avatar
Originally Posted by MK2
Gene,
Lin
Good Morning Lin,
Door hinges is what I'm having trouble with. I didn't even know that the windows had shims. Maybe that was what the wood was being used for? It was deteriorated to almost nothing so not much use. Oh wait - there were several washers under the window frame. I'll take a pic of those and post in the next couple days.
It's so nice to have a reference like yours to refer back to. Thank you for maintaining that site I'll review it as soon as I finish this post.
Gene
Old May 22, 2019 | 03:50 PM
  #223
TilleyJon's Avatar
Those shims look like the ones for the window frames on top of the door.
Here is a pic of one of the shims on my doors. This one is obviously a bottom hinge.
Old May 23, 2019 | 09:33 AM
  #224
gene61jag's Avatar
I understand the confusion now. I do not have full-size shims for my driver-side door. I have smaller U-shaped versions that slide on and off the bolts. I'll try to provide pics at some point. Yes, they have the same shape as the "packing pieces" that hold the chrome window frame up, but my door hinge shims are bigger than the window frame pieces.
Old May 24, 2019 | 09:07 AM
  #225
littlelic69's Avatar
I very much like that write-up. Could have used something like that when I restored mine .Alec G.
Old May 24, 2019 | 10:29 AM
  #226
gene61jag's Avatar
This forum is an AMAZING resource. When I have folks like Lin, Jon, Chuck and many others responding to my questions I understand the meaning of the statement "standing on the shoulders of giants". Cheers!
Old May 24, 2019 | 11:51 AM
  #227
TilleyJon's Avatar
That's very kind Gene, with the support of others we all (including myself) grow a little taller, no-one can know what they have not learn't and it is an ignorant man that thinks he knows everything.
There is a wealth of combined knowledge on this forum, with different experiences. I have and always will take my hat off to Lin for the gargantuan effort he has put into his Valve Chatter site and for continuing to maintain it as such a great reference.
Keep up the good work Gene and everyone else.
Old May 24, 2019 | 08:43 PM
  #228
MK2's Avatar
MK2
Thanks to Gene and Jon. Glad to hear the old website remains useful!
Lin
Old May 28, 2019 | 01:11 PM
  #229
gene61jag's Avatar
Lin
Very much so Lin. If you want help maintaining the site let me know. At least let me buy you an iced tea if we meet in our travels
Old Jun 18, 2019 | 11:59 AM
  #230
gene61jag's Avatar
Sorry for the delay. This is the pic I took of the 3 shims/packers that dropped from my door. I re-installed them all on the bottom hinge and the door closes easily. Glasses clips in the pic to show scale
Old Jun 18, 2019 | 01:12 PM
  #231
TilleyJon's Avatar
Those shims are as you say similar the glass frames, if they are solving the problem, then stick with them.
Old Jun 18, 2019 | 04:14 PM
  #232
gene61jag's Avatar
Sounds right to me too. At some point I will probably replicate the shims that you and Lin have been talking about.
Old Jun 18, 2019 | 04:58 PM
  #233
csbush's Avatar
Nice work Gene- glad you fixed your problem!
Old Oct 9, 2019 | 02:40 PM
  #234
gene61jag's Avatar
Just a video of a recent drive. She does alright for an old car without an overdrive, and I love the sound of her engine:
Old Oct 9, 2019 | 04:54 PM
  #235
MK2's Avatar
MK2
Very nice, Gene. Love the sound, too and the ride seemed pretty smooth.
Lin
Old Oct 10, 2019 | 11:00 PM
  #236
gene61jag's Avatar
Lin
Thank you sir. She does alright for an "older lady"
Old Jun 13, 2021 | 10:19 PM
  #237
gene61jag's Avatar
Was not sitting on my laurels all of 2020 but I could have removed more rust I guess. I have been working to procure "bits" for my interior. Wood trim kit came late last year and this week I put the glove box together. LOTS of "fiddly bits":
Old Jun 25, 2021 | 09:43 AM
  #238
Bill Mac's Avatar
Gene
I am a bit late in entering your thread. However I after over 55 years of older Jaguars I would tender these observations.
Low oil pressure, especially after a long run:
As long as the idle oil pressure remains around 10 to 20 PSI there is no problem. My first Mk7 Jaguar when I was 21 which is over 55 years ago did that and I was advised by the local Jaguar dealer (Westco Motors) that this is normal. Their advice was to remove the oil filler cap while the engine was running and if there was plenty of oil moving through the camshaft covers all would be OK. I suspect they were experts as they were also racing a D type and a MK 1, Actually Jaguar changed oil pressure gauges from 0-100 PSI to 0-60 PSI as customers were concerned at the very low gauge indications. There has been a lot of garbage disseminated over the years about Jaguar oil pressure which is sheer bull ---t..
MK2 Jaguar Oil pressure gauges tell lies
I have found again and again that the MK2 oil pressure gauge is an unreliable piece of pommy( Australian for English) junk. You need to use a direct reading gauge to see what is really happening. I sorted one out a few years ago where the owner was about to commit to a an engine rebuild based on low oil pressure. Using a direct reading gauge the oil pressure was OK.
DG250 Automatic Gearboxes
I scanned your previous problems with this auto box. Nobody raised the problem of possible low oil. The DG box weirdly requires that the engine is running with the gear selector in L to check oil level in the gear box. I have owned 1 Auto MK1 and 2 Auto MK2s and assure you this is correct. I have also checked my original Jaguar factory workshop manual and the procedure is on Page A24.
I hope this helps
Old Jun 25, 2021 | 11:38 AM
  #239
Peter3442's Avatar
I'd second what Bill wrote on oil pressure. In my experience, the most likely cause of a low reading is the gauge itself. That's followed by the pressure relief valve. Wear in the engine is the last place to look. The gauge is useful for showing sudden changes and that the oil is warmed up and it doesn't have a capillary to crack and leak, but, apart from those aspects, it's not the finest instrument in the world in other words rubbish.
Old Jun 26, 2021 | 08:03 PM
  #240
Bill Mac's Avatar
Peter
Re-low oil pressure especially at idle.
Thanks for the wake up call on the oil pressure relief valve. I should have mentioned it in my post. On two occasions I have found that the oil pressure relief valve was the culprit. Once on one of my own cars and another on a friends car. In both cases the faces of the valve were worn and they were refaced on a lathe.
Bill Mac
MK1
MK2
S3XJ6
X300
Previous 4 MK1, 4 MK2, 2 MK7, MK8, 420G, S2XJ6, XJ40,
