1963 MK2 rear hub removal...
Old Mar 26, 2020 | 03:36 PM
Homersimpson's Avatar
Originally Posted by Banyie
Well he finally got it off,
He used a large puller with an electric jack hammer on the end of the puller and it just popped off.
The other 3 came off straight away.
Unfortunately though we damaged the drivers side half shaft, as the new nut will not go on.
So next job is buy a new half shaft and bearing
Before you buy a new halfshaft, you might try what I did when I did the same thing which was to buy a die nut, cut it in two and then put in on the lower section of the shaft where the thread was good and wind it back off cutting a new thread as it went. It worked perfectly and a cheap die nut was around £10 on e-bay and the die wrench was about the same.
Old Mar 26, 2020 | 03:39 PM
Banyie's Avatar
Yes that would be a better Idea, I did suggest re-threading it.
What would we search for just nut and tool?
Old Mar 26, 2020 | 03:41 PM
Banyie's Avatar
Sorry what I mean is, the nut was imperial and I'm not sure what to type in on ebay search engine
Old Mar 26, 2020 | 03:46 PM
I think mine was a 7/8 14 UNF die like this https://www.ebay.co.uk/itm/UNF-DIES-...o5y9KK4a1sRBqQ
Possibly cheaper from a chinese supplier but probably not a good idea to order direct at the moment....
sanchez
XJ40 ( XJ81 )
May 18, 2018 09:33 AM
Davexj8
Apr 25, 2017 06:56 AM
terebyte
XJ40 ( XJ81 )
Feb 23, 2016 06:10 PM
Xcellr8
Dec 13, 2011 11:50 AM
oldmainsfishing
Aug 9, 2009 05:09 AM
