64 Jag MK2 hard fuel line fitting
Old Apr 4, 2017 | 01:32 PM
MK2's Avatar
MK2
Default 64 Jag MK2 hard fuel line fitting
Can anyone tell me the size of the fitting used on the hard fuel line from the rear of the car to the fuel filter under the bonnet? It "seems" to be 1/2"-20 but I want to be sure since we obviously don't want any fuel leaks!
Thank you.
Lin
Attached Thumbnails 64 Jag MK2 hard fuel line fitting-jag-mk2-fuel-line-fitting.jpg
Old Apr 4, 2017 | 04:00 PM
TilleyJon's Avatar
Lin it may well be 1/4" BSPT
Specs are :-
19 TPI 0.518" OD
I will try and find a definitive answer for you
Old Apr 4, 2017 | 04:32 PM
TilleyJon's Avatar
I can't find a definite answer, but the balance of probability is 1/2" UNF x20 as you thought, this was common on AC delco parts from the 40's to 80's, also used on Stromberg carbs, Delphi fuel filters use the same thread, and the nuts and olives are freely available on the web, but I can't find any of the correct fittings in the 1/4" BSPT, so I would go with 1/2" UNF, you must have a spare bolt you could try ?
Old Apr 4, 2017 | 04:59 PM
MK2's Avatar
MK2
Jon,
Yes I tried a 1/2"-20 nut on the fitting and it seems to work just fine, but I just found it hard to believe that this fitting would be a UNF thread.
Lin
Old Apr 5, 2017 | 02:48 PM
TilleyJon's Avatar
Originally Posted by MK2
Jon,
Lin
I thought that too, but it turns out that its a very common thread size, the brake fittings are 3/8" UNF, so it does kinda follow.
