Aluminium Nacelle / Switch Cover / Cowling
When I see his post i will ask him George. I have a perfectly preserved turn signal / overdrive lights assembly with harness and fittings, it fits perfectly into the aluminium top half, bolts the same way too. Definitely MK2.
That's the first time I've seen the ribbed covers unpainted _ they look great !
I never like the painted ones on the 240/340; looked to modern for the car.
Always looked like someone stuck in a 4.2 litre XJ engine where it doesn't belong.
Thanks guys.
They take a bit of stripping back, the sides are slightly textured, so they have to be sanded up to (or down to depending or your view) 1200 grit then polished, I painted in between the ribs with Gunmetal grey to match the exterior, I was quite pleased with the result, they suit the engine I think, not as good as the smooth covers of pre '67, but ok.
I have been sanding that nacelle for 3 days by hand. I am beat. And now comes the actual polishing to make it like chrome. Then I will fit it to the S type and decide if polished aluminium is a big mistake. Not to mention the switch notches will have to be enlarged.
My MK2 was the first 3.8 (Chassis 210001) and has the indicators on the right. The surround is Bakelite not metal.
