Best tool for double flare brake lines???
Old Nov 16, 2020 | 12:40 PM
jhemp's Avatar
Default Best tool for double flare brake lines???
what is the spec for the brake lines...what diameter brake tubing?
best tool for a good looking double flare? source?
thanks
Old Nov 16, 2020 | 09:52 PM
lickahotskillet's Avatar
https://www.eastwood.com/professiona...iABEgJbL_D_BwE
My favorite above. You can go back through my thread on my MK2 to see it set up for use.
Old Nov 16, 2020 | 09:53 PM
Excellent price right now in the link I sent.
Old Nov 17, 2020 | 07:13 PM
I use brake assembly lube on the die and line when making the flare. Also don't over pull the lever on either step. Lube & right pressure prevents the metal from splitting. Do test flares to learn any tool.
Old Nov 19, 2020 | 06:23 PM
Jim Rankin's Avatar
I bought the Eastwood tool to make all new brake lines and to adapt some metric new bits. It's an investment that really does pay for itself quickly. As noted, you do not need to yank on the tool, slow steady pressure and you will feel the tool bottom out where it is supposed to. Bought some greasy copper colored lube and the metric dies and mandrel and everything worked like a charm.
zoolander
Feb 21, 2014 03:10 PM
Bumbazor
Jul 25, 2013 06:14 AM
KCME
May 13, 2012 08:40 AM
TysonsJag
Oct 31, 2011 10:58 PM
