Bolt thread question
Old Aug 2, 2024 | 11:34 AM
Peter3442's Avatar
Originally Posted by Jagboi64
No, they are the same thing! It's called a bolt is when the threaded fastener is used with a nut to make the joint and the nut is turned to tighten. A cap screw goes into a tapped hole and the head of the fastener is turned to tighten. However, the fastener itself can be identical, but called different names depending on how it is used (nut or no nut).
In the UK, if a 'bolt' that is threaded its full length is usually a set screw rather than a bolt, while a bolt has a thread that doesn't go all the way to the head. Yikes, it's easier to say give me one of those ...
As for Rob's scones, that's the perfect analogy.
Old Aug 2, 2024 | 12:01 PM
Cass3958's Avatar
Originally Posted by JeffR1
No No, jam first, it's stickier then cream so it can be spread into the scone (also fills the holes in a crumpet as well)
Then cream...
If you try and put jam on the cream, then you get cream all over the knife and if you need more jam, then the jam jar gets full of cream.
Also, if you try and spread the jam around on the cream, the cream will just get all over the place.
If the jam didn't set, then I suppose...
How could it possibly work well with cream first and then jam ?
Jeff you put the jam on with a spoon so you get a great big dollop on top of the cream which you have spread with a knife.
williamk123
Oct 15, 2023 03:51 PM
Higgins
Dec 27, 2020 03:24 PM
Johnny V
Jun 21, 2018 06:51 AM
LeapingCat
Mark V - X 420G
Feb 22, 2014 12:39 PM
scyzoryk
Jul 25, 2011 03:33 PM
