Exhaust question
Old May 31, 2015 | 07:41 AM
redtriangle's Avatar
Default Exhaust question
Greetings gentlemen,
My Mark II (sorry Mk 2) exhaust system (downpipes & mufflers) are shot.
I have a XJ6 4.2 lump which I am considering fitting later on, so the question is, what size pipes would be required given engine capacity may go up from 3.4 to 4.2 litres.
I am thinking 1 & 7/8" would be the go.
Standard pipes ( complete with rust) seem to be around 1 & 5/8" at the tail.
Any suggestions welcome!
Old Jun 1, 2015 | 02:41 AM
Stoney85's Avatar
I cant comment on what specifics the Jags have been using, but both my E34 BMWs have been running a twin 2" system from factory, being a 3.5L straight 6 and a 4L V8.
Both have very large and heavy cats, resonators and box mufflers.
There is calculations out there if you know your engines power/torque and max RPM limit.
Larger diameter is better for higher RPM use, less restriction up high, but can also affect low rpm torque due to limited back pressure
Old Jun 1, 2015 | 08:06 AM
Jose's Avatar
I removed both exhaust systems in my XJ and S type, and then reinstalled brand new stock systems in both, all by myself with the cars on blocks, one piece at a time, but I never measured the diameter of the pipes.
Having said that, I believe the XJ pipes are indeed 1 and 7/8" diameter, and the S type's are 1 and 5/8", so you might have it correctly. However, the stainless steel Tips are narrower in the XJ 4.2 than they are in the S type 3.8, which contradicts the measurements of the pipes.
Here's a picture of the complete exhaust system for the S type before I installed it, and a picture of the European 'Y' pipe I installed in the XJ-6. (the European 'Y' pipe does not have the second catalityc converter found in US cars).
Attached Thumbnails Exhaust question-s-type-exhaust-b.jpg   Exhaust question-xj-6-exhaust-y-pipe-assembly-xj-6.jpg
Old Jun 2, 2015 | 09:08 AM
Many thanks for the advice. Think I will go with the 1 & 7/8", although to my disappointment , my local exhaust guy (early 20's) says "get with the times, we now use metric measurements"
silkcat
Jan 18, 2025 04:29 AM
Daim
Nov 28, 2016 09:28 AM
Aus V8S
Nov 13, 2015 11:01 AM
Dickie_L_J_O
Sep 13, 2015 07:44 AM
XJ8JR
Sep 11, 2015 12:31 AM
