got around to reassembling the front hubs of my mk2 with wire wheels. When I took it apart it had no water deflectors, so I ordered some - when I try and assemble them as per the cross section drawing in the workshop manual they don't appear to fit on either the hub or the stub axle carrier.
I've attached some photos - can anyone tell me whether I just need to 'pursuade' them, whether I've got the orientation wrong, or whether it's just that my car doesn't require them?
Any thoughts, or photos of others' installations would be greatly appreciated.
My photo is of the hub, and yours of the upright/axle carrier - hence the different part shapes. I managed to get the deflector on the hub with some gentle taps of a rubber mallet - but I'm still struggling with the part on the upright. The OD of the carrier at that point is 52mm and the ID of the deflector is 50mm so its never going to fit! Can only assume I've got the wrong bit :-(
It seems there's two part numbers that may apply, depending upon chassis number. Here's the info on the SNG Barratt site.
Regards
STUB AXLE CARRIER
STUB AXLE CARRIER
WATER SHIELD, on Stub Axle Carriers
FOR CARS FITTED WITH DISC ROAD WHEELS Fitted from Chassis No. 150001 to 155970. 175001 to 177301. 3.4 litre. 200001 to 205345. 210001 to 217575. 3.8 litre. FOR CARS FITTED WITH WIRE SPOKE WHEELS Fitted from Chassis No. 150001 to 156139. 175001 to 177
NOT AVAILABLE ONLINE
MORE INFO / SEND ENQUIRY
PRODUCT CODE: C18642
QUANTITY OF FIT: 2
[BACK TO TOP]
FOR CARS FITTED WITH DISC ROAD WHEELS Fitted to Chassis No. 155971 and subs. 177302 and subs. 3.4 litre. 205346 to 210000. 230001 and subs. 217576 and subs. 3.8 litre. FOR CARS FITTED WITH WIRE SPOKE WHEELS Fitted to Chassis No. 156140 and subs. 1773
WATER SHIELD
MORE PRODUCT INFO
PRODUCT CODE: C18843
QUANTITY OF FIT: 2
RETAIL PRICE: £11.10 (£13.32) inc VAT SPECIAL ORDER ONLY Quantity: Add to basket
ALTERNATIVE PRODUCTS
WATER SHIELD
MORE PRODUCT INFO
PRODUCT CODE: C18843#
YOUR PRICE: £8.21 (£9.85) inc VAT IN STOCK Quantity: Add to basket
Thanks for the info - I think as the former wasn't available on the internet I overlooked it, and ordered the wrong part. I've enquired with SNG about availability of the other bit.
No luck so far - SNG don't stock the other part, and a couple of other places only stock parts that are too small. Starting to wonder if I've got non-spec uprights!
Current fitted with hub side part only due to lack of time - at least their easy to fit later!
