gauges not working
Old May 11, 2023 | 10:17 AM
Jose's Avatar
Old May 11, 2023 | 06:01 PM
Glyn M Ruck's Avatar
Originally Posted by Bill Mac
Glyn
I would add diode protection and make it atomic bomb proof.
That would also work well Bill. I'm being cheap.
Old May 11, 2023 | 07:19 PM
Bill Mac's Avatar
Glyn
Diodes are also very cheap. Mostly sold in a pack of 10 ranging from 2 to 5 dollars a pack depending on amperage rating.
I would use a 5-amp diode which should be more than capable of passing the drain on the system.
Old May 12, 2023 | 08:23 PM
The only reaason I like pico fuses, other than price, is that it is so easy to check if they are blown. But diodes are pretty easy to check as well to be fair as long as they blow infinite current.
Old May 13, 2023 | 03:24 AM
Peter3442's Avatar
The purposes are slightly different (I think). A capacitor or diode across the input (and possibly output) of the IC filters off voltage spikes. A fuse on the live output protects against shorts to ground. On the live input, it would protect against current surges. Personally, I'd settle for a pair of ceramic capacitors (in series) across the input. On the output side, it depends on the sensitivity of the IC to shorts. At some point, it costs no more to replace the IC than whatever is protecting it. In fact, the cost is the time and inconvenience.
JagNZ
Oct 7, 2022 07:46 PM
crvols
May 7, 2022 10:31 AM
brinny
Mar 31, 2019 03:53 PM
solerunner
Sep 29, 2011 08:18 PM
kzguns
XJ40 ( XJ81 )
Jun 18, 2010 12:16 PM
