Horn Relay location 1967 420
Old May 8, 2021 | 07:16 PM
tsmatsoukas's Avatar
Default Horn Relay location 1967 420
My 420 came sans horns. The po had not worried about it but I live on a crazy busy highway (bloody 98) and feel the need.
I have mounted a set of horns but do not see any relay.
Can I get a location, or picture of the stock relay location.
The parts book and manual have a close up of the location, but I can't make out if it is a wing or firewall???
pls n thx
Old May 9, 2021 | 12:43 AM
Glyn M Ruck's Avatar
If it follows S Type convention, which I think it does, it will be right at the front of the RHS inner wheelarch. Otherwise check front LHS wheelarch.
Agree this is not the most helpful diagram. Hopefully a 420 owner will chip in.
Old May 9, 2021 | 03:08 AM
Cass3958's Avatar
As Glyn has stated on the S Type the relay is located on the inside of the front wing in the engine bay just behind the radiator and above the brake servo. Difficult to photograph so I have gone back through my assembly and disassembly photos and found these two which might help.
Old May 9, 2021 | 05:12 AM
Peter3442's Avatar
The standard position on a Mk2 (when fitted) is adjacent to the fuse box. However, I'm sure that I've seen one near the slip ring connections on the steering column. That may well have been an owner upgrade.
Old May 9, 2021 | 06:47 AM
The connector you see above it in the diagram & 2 earth loops are the lighting connectors for the sub-harnesses that go the respective units headlights, sidelights, flashers etc. for one side. Not yet fitted here. Taped wires here.
Horn Relay
420 Harness layout
I think what you see to the left of the diagram is supposed to be the Saginaw PS pump & drive.
Earth connector above main lighting connector block.
Jose's Avatar
in both my 1965 S type and my 1984 XJ-6, the horns relay is mounted on the left inner wing as you stand in front of the car looking at it, Behind the radiator halfway down in both cars. Check the fuse, those relays rarely go bad.
jomo
Apr 12, 2023 03:20 PM
PerErs
Jul 5, 2019 03:47 PM
Terrific
Jul 21, 2018 01:56 PM
user 2029223
Nov 5, 2015 03:46 PM
Mr. Barry
E type ( XK-E )
Oct 3, 2014 11:44 AM
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
