Jaguar MK2 1959 Unusual Front Bump Stop
Old Sep 25, 2016 | 03:11 PM
Homersimpson's Avatar
Default Jaguar MK2 1959 Unusual Front Bump Stop
Hi,
I've just started to rebuild the front suspension on my 1959 MK2, I have discovered that the top front wishbones are pressed steel rather than the cast/forged type used on the later years.
The two halfs of the wishbone bolt together at the ball joint the same as later cars bu they also have a tap on each one which has a bolt running through.
Sandwiched between the two halfs and held by the bolt is an inverted T shaped piece of metal onto which is bonded the upper bump stop.
This doesn't seem to be in the MK2 or MK1 parts books that I have, has anyone come across this?
Thanks for any help you can give.
Old Sep 26, 2016 | 03:16 PM
I've taken a photograph of the bump stop. Its a metalastik unit and has the number 15/1077 on it.
Does anyone have any idea where I can get these from?
Thanks for any help you can offer.
Attached Thumbnails Jaguar MK2 1959 Unusual Front Bump Stop-img_20160926_210411381.jpg
Old Sep 26, 2016 | 04:01 PM
TilleyJon's Avatar
Hi
The part no you need should be C15701, page 255 of the parts manual (hopefully), the bad news is these are no longer available.
I have a complete spare front axle from the same year, which I need to refurbish at some time.
You have to replace the complete wishbone with the newer type together with new bolts washers and new style rebound stops.
I will dig more to see what I can come up with
Jon
Old Feb 2, 2026 | 04:01 AM
Signorp's Avatar
Default Bump stop C15701 unusual part
Dear Jon,
I saw your discussion on the forum and i come back to you because i need the bump stop C15701 for my MK2 2.4 Lt .
Do you have some available after restoring your front suspension?
Thanks in advance
Best regards
Peter3442
Jan 21, 2026 12:47 PM
GGJag
Dec 29, 2024 04:11 AM
MussieRon
19
Aug 26, 2023 11:04 PM
