LHD or RHD PAS (power steering box)
Old Sep 26, 2022 | 08:33 AM
hdrop's Avatar
Default LHD or RHD PAS (power steering box)
Hi all,
still having problems with my PAS en found a donor for sending to ICS for repair.
I need a LHD box but the problem now is of the donor is a LHD or RHD.
If someone can help please with the help of attached pictures.
Greetings Hans
Attached Thumbnails LHD or RHD PAS (power steering box)-donor-pas-1-.jpeg   LHD or RHD PAS (power steering box)-donor-pas-2-.jpeg   LHD or RHD PAS (power steering box)-donor-pas-3-.jpeg   LHD or RHD PAS (power steering box)-drop-arm-1-.jpg   LHD or RHD PAS (power steering box)-drop-arm-2-.jpg
LHD or RHD PAS (power steering box)-drop-arm-3-.jpg   LHD or RHD PAS (power steering box)-drop-arm-4-.jpg   LHD or RHD PAS (power steering box)-my-pas.jpg   LHD or RHD PAS (power steering box)-my-pas.png
Old Sep 26, 2022 | 10:47 AM
Glyn M Ruck's Avatar
As I've pointed out in PM's (sorry my box is full & needs a clean out.
The HALE is correct for the "second type" box in Jaguar speak.
The weedy drop arm & idler arm shown are for Manual steering. The PAS arms were beefed up in case one turned against a curb. The manual arms would bend.
Let me find you a thread that I posted in to show the difference.
See posts 30 & 33 here. Maybe someone else can tell the mounting points on the box & tell you whether it's LHD or RHD. I can only tell from the drop & idler arms. Your pictures only show manual steering arms.
https://www.jaguarforums.com/forum/m...-260626/page2/
Old Sep 26, 2022 | 11:49 AM
Peter3442's Avatar
On my RHD car with manual steering box, the input shaft from the clumn is offset away from the engine (i.e. to the right). It seems likely that LHD will be the opposite.
If it helps, I think that, when viewed from above, the PAS steering drop and idler arms are curved, while manual are straight.
Old Sep 26, 2022 | 01:52 PM
hdrop's Avatar
Thanks Glyn, I noticed your full mailbox when I tried answered on your last mail.
Old Sep 26, 2022 | 04:12 PM
Correct ~ the PAS arms are curved & have a protrusion in that curve to bump against the new lock stops fitted to PAS cars.
This is a LHD car
This is a RHD car.
This is a LHD car.
Old Oct 3, 2022 | 04:57 AM
hdrop's Avatar
My donor PAS is definitly a RHD type 1 as Glyn mentioned earlier.
I send the pictures to ICS / DASteering so that they can tell me if the RHD parts can be used for repairing my LHD PAS.
I will keep you all informed of the progress.
Old Oct 3, 2022 | 05:17 AM
I've cleared my mailbox so it will now accept PM's. Your car should have a type 2 steering box. Type 1 & 2 parts are not interchangeable. Type 1 short exterior pipe. Type 2 long exterior metal pipe.
Unless your car is a '64 build first registered in '65.
JohnCIW
Mar 16, 2021 05:46 PM
Mauro Corda
Oct 20, 2019 10:20 PM
hdrop
Sep 28, 2019 09:45 AM
kennyjd
Feb 11, 2016 01:09 PM
_Dom_
Mark V - X 420G
Oct 11, 2015 01:25 PM
