Looking for a Water Rail
Old Jun 18, 2023 | 01:25 PM
Felixbobcat's Avatar
Default Looking for a Water Rail
I need to get a water rail for my S Type. The outlet end for the heater snapped off and I don't want to try and have it welded back on since the threads are damaged meaning it will need to be heli coiled which will probably leak. It's part number C15800/2.
So checking to see if anyone here has one they'd like to unload.
Old Jun 18, 2023 | 04:15 PM
Glyn M Ruck's Avatar
That got broken off trying to remove a corroded heater piping steel nipple. It's better just to cut the nipple & collapse it. Then screw in a new one & maintain coolant concentration thereafter.
Wish I could help but I'm keeping my spare. They usually corrode at the pipe at the Otter switch end and I have a pristine one.
Old Jun 18, 2023 | 09:21 PM
Bill Mac's Avatar
Those water rails are common to MK1, MK2 and S type 3.4 and 3.8 engines.
However, they have become extremely scarce to near impossible to find (as Glyn says) because they corrode the pipe at the end near the otter switch.
I have been trying to find one for a friend for a couple of months now. I do have a spare but I am keeping it for my cars.
I suggest you get it welded and helicoiled and use a jointing compound like "Stag" to stop any leaks.
An alternative would be to weld up the heater outlet and redrill and tap the hole for a new fitting.
Old Jun 19, 2023 | 06:00 AM
This is the cursed thing. After this pic I cut & collapsed mine & fitted a new one. It was corroded solid in the aluminium. It was in far worse condition than the pic shows. Pics do lie.
Old Jun 19, 2023 | 06:18 AM
Coventry Foundation's Avatar
Felix you might look here. https://www.ebay.com/str/coventrycol...at=42862724011
Old Jun 19, 2023 | 05:46 PM
Thanks for the help guys. I found a local Jag restorer who had several to choose from. He doesn't restore Sedans but still has a lot of parts that I may need at some point. Very good resource to have close by
Old Jun 19, 2023 | 06:06 PM
That is good news for you.
Pay extreme attention to the state of corrosion on this pipe. Choose a good one. I also replaced all my heater pipes with stainless steel. They also have a habit of being badly corroded from people being careless with coolant concentration or just using plain water. When these cars had little value they were carelessly treated by many.
cityboy
Sep 22, 2021 10:08 AM
Martyb
Jun 16, 2020 09:03 PM
sarahsmi
Sep 8, 2017 03:20 PM
Billwood
Jun 2, 2017 01:31 AM
Rosspot
XJ40 ( XJ81 )
Nov 30, 2014 02:49 PM
