Mark 1 engine is racing
Old Dec 2, 2022 | 11:27 AM
jrosenfeld's Avatar
Default Mark 1 engine is racing
As I started my 1959 3.4 litre Mark 1 today the engine started racing at about 2,000 rpm. I drove it around a bit and the idling revs went up to 3,000 rpm when I came off the gas pedal. I adjusted the idle down to 1,000 rpm with the idling screws on the carburetors but as soon as I pushed the gas pedal the engine started racing again. Is this a problem with the gas pedal linkage or is it in the carburetors? Any advice would be most welcome.
Old Dec 2, 2022 | 11:55 AM
Glyn M Ruck's Avatar
Are your 2 Throttle return springs in good order. The other thing that can happen is that the throttle lever has not been sufficiently tightened & slipped on the throttle butterfly shafts.
Old Dec 2, 2022 | 12:33 PM
Schmitty's Avatar
I would make sure the gas pedal itself is not hung up on something that keeps it from returning to its normal position. I would then check to see if possibly a return spring in the linkage has come off or broken, as Glyn gives good advice.
Schmitty
Old Dec 2, 2022 | 02:41 PM
jrosenfeld's Avatar
Thanks Glyn and Schmitty for your advice. I had neglected to reconnect the throttle return spring when I removed the air intake to change the spark plugs. Once reconnected, it runs very nicely. By the way, I found a complete 282 page shop manual for the car online at: https://jaguarrules.ru/wp-content/up...hop-Manual.pdf
Old Dec 2, 2022 | 04:49 PM
JeffR1's Avatar
Yeah, don't want to be a wet blanket, but that Haynes manual is incomplete in many areas.
There are links here on the forum to factory manuals.
Old Dec 2, 2022 | 05:46 PM
Pleased you are sorted! Sorry ~ I keep forgetting it's a Mk1
3.4 only ~ remember there are 2 throttle return springs with SU carbs. 75 & 76. ~ 2.4 had Solex carbs until 240 arrived.
Old Dec 2, 2022 | 06:20 PM
Schmitty
Thank you Schmitty
Old Dec 2, 2022 | 06:26 PM
jrosenfeld's Avatar
Thanks. I had only disconnected one. The car is running beautifully now.
Old Dec 2, 2022 | 06:28 PM
jrosenfeld's Avatar
Thanks Jeff. I'll look around the forum for a better manual.
Old Dec 3, 2022 | 02:20 AM
Yes ~ they are very gentle springs ~ one would presume to prevent throttle/butterfly shaft wear.
Old Jan 13, 2023 | 11:32 AM
Jagfixer's Avatar
Is the starting solenoid shutting off? Are dashpots full?
Old Jan 13, 2023 | 06:50 PM
Quote "Thanks. I had only disconnected one. The car is running beautifully now."
Mboo66
Jun 25, 2017 12:08 AM
l3uddha
Aug 11, 2014 09:19 PM
Vee
Mar 15, 2014 12:36 PM
MLRocafella85
Jun 22, 2011 11:20 AM
Peterch
May 4, 2011 08:55 PM
