Mk 2 Map Light
Old Oct 25, 2014 | 09:26 AM
grey nick's Avatar
Default Mk 2 Map Light
I have just bought a map light for my 1967 340 MOD and it had two plastic (Bakelite) pieces. One has all the gubbins on it (connection, bulb etc) and the other simply has two screw holes. I know the gubbins bit fixes on the return on the dash top, does anyone have any idea what I should do with the other bit?
regards
grey Nick.
Old Oct 25, 2014 | 04:39 PM
Jose's Avatar
does it look like any of these ?
Old Oct 25, 2014 | 04:55 PM
Fraser Mitchell's Avatar
Surely that is the glove box light not the map light ?
Old Oct 26, 2014 | 01:19 AM
Jose's Avatar
one of them is the Glove box lamp assembly, the other is the Map Light, both as used in the S type of 1963-1968
Old Oct 26, 2014 | 05:03 AM
grey nick's Avatar
Default MK2 Map Light
Thanks Guys
I first thought that the extra piece may have been as a burn protection above the light to stop the bulb burning the underside of the wood dash top but think that idea may be a bit silly.
I could put it in as a spacer behind the fitted strip to hold the whole assembly a little off the wood, but if that was the intention why not have it fitted there in the first place.
I do not know if the photo helps but any advice I get will be appreciated.
Old Oct 26, 2014 | 02:00 PM
GT6Steve's Avatar
I've been kicking around buying one of the LED lighting strips to fit under the dash in lieu of the factory single bulb map light. I haven't looked into it yet, just at the thinkin' stage just now.
Old Oct 26, 2014 | 02:54 PM
Jose's Avatar
yes, it is a spacer in case you need it.
Shawn Svacha
Feb 6, 2022 04:53 PM
Donzi
Oct 18, 2018 12:26 AM
motorhead69
Sep 9, 2015 10:04 AM
pegasus3710
Sep 5, 2015 09:40 AM
gene1
Sep 3, 2015 05:58 PM
