MK 2 Parking Brake Compensator Spring
Old Aug 19, 2023 | 03:15 PM
LBL591E's Avatar
Default MK 2 Parking Brake Compensator Spring
I’m trying to figure out how to fit a new spring to the vertical shaft, which has welded fittings preventing a simple slip on….. any suggestions most welcome! Thanks, Ralph
Old Aug 19, 2023 | 07:21 PM
cdg66mk2's Avatar
Hi Ralph. I took a trip to the basement to have a look at mine and sure enough, it's welded at both ends. I guess the only option is to peel it off the shaft one coil at a time. My spring was in good shape so it was media blasted and painted with the spring in place.
Old Aug 19, 2023 | 09:00 PM
LBL591E's Avatar
Thanks for the note…. That confirms my suspicion. I guess its time to be bold and break out the cutters! Regards, Ralph
Old Aug 20, 2023 | 03:21 AM
Glyn M Ruck's Avatar
It was probably available as a complete assembly at one time. A bit dumb.
Old Aug 20, 2023 | 10:28 AM
Homersimpson's Avatar
I recall taking both of mine to bits, do you not undo the nut at the top?
Old Aug 20, 2023 | 10:54 AM
LBL591E's Avatar
The spring is held captive by flanges/washers welded top and bottom to the shaft, so the only way to fit a new one (readily available) is by cutting off the old spring and somehow ‘winding’ the new one on to the shaft….. which must have been the way they were originally made…. I can’t see welding these bits to the shaft with the spring in place….
Old Aug 25, 2023 | 05:43 PM
Fraser Mitchell's Avatar
I'm pretty certain I had mine in bits when I rebuilt my Mark 2 in the 80s, but I may be wrong, as it was a long time ago. I had a nut welded on the side in a position between the two bushes. Yes, Jaguar put in bearing bushes, but made no provision AT ALL for lubrication. After the nut was welded on, I just drilled a hole through.
Old Aug 25, 2023 | 06:06 PM
LBL591E's Avatar
No bearings or bushes on this assembly…… perhaps you were working on a different item…?
Old Aug 26, 2023 | 04:10 AM
Cass3958's Avatar
Perhaps your item is not original and has been altered to fit. Just thinking outside the box.
The S type has a different hand brake set up so I have no experience with this assembly. I have had a look at the parts list and diagram and it is not detailed enough to see if it comes apart but here are the diagrams anyway with the part list and number. C20745.
rod9669
Mar 13, 2023 06:18 PM
adenshillito
Apr 16, 2021 10:01 AM
pelle
Jan 25, 2018 09:16 AM
Adam Lueb
Jul 19, 2016 12:55 PM
Lionrod
Aug 30, 2015 12:52 PM
