MK1 2.4
Old Mar 28, 2018 | 01:45 PM
melhookv12's Avatar
Default MK1 2.4
Circa 1956, replacing the engine/light instrument loom.
I have the wiring in the loom for front indicators ( blinkers USA peeps ). But I don't have link harness.
The rear wiring flashes the stop lights to act as an indicator.
Help on the front, were they fitted, did the side lights flash.
Old Mar 28, 2018 | 02:29 PM
TilleyJon's Avatar
The lights in the front are twin filament Lucas 380 lamps, one filament for the side light and one for the flasher.
Similar setup to the rear, but one filament is the side light and the other is both stop and flasher.
Do you have a wiring diagram ?
Old Mar 28, 2018 | 03:01 PM
melhookv12's Avatar
Hi Tilley, yes I have a Haynes manual showing the wire colours, so I'm ok there.
Are the lamps earthed through the lamp housing ? The connector on the back is a 2 pin bullet style.
Old Mar 29, 2018 | 12:31 AM
TilleyJon's Avatar
The lamps should have an earth wire, see attached image from workshop manual.
File Type: pdf
Old Mar 29, 2018 | 01:54 PM
DaimlerMK2's Avatar
Hi Melhookv12.
you going to put a v8 in it.
JimC64
Aug 9, 2011 11:05 AM
Parnell
Jun 17, 2011 04:02 AM
lordarun
Mar 22, 2011 02:34 PM
dre2kx
Aug 12, 2010 12:07 PM
cust3
Jun 2, 2008 03:31 PM
