Mk2 axle oil-seal gaskets
Old Sep 6, 2017 | 07:40 PM
Hemisfear's Avatar
Default Mk2 axle oil-seal gaskets
I'm rebuilding the rear brakes and installing new outer oil seals on my Mk2 and confused about how many paper gaskets there should be. My car had only one each side (under the oil-seal retainer plate), shop-manual diagrams only show one, but parts manual says there should be two, and so do some online resources. Anybody know what is correct?
Old Sep 6, 2017 | 09:09 PM
Jagfixer's Avatar
You have the inner seal, shims, backing plate, paper gasket, retainer, paper seal, oil seal container with seal, then hub.
Old Sep 7, 2017 | 12:51 AM
TilleyJon's Avatar
I thought there was only 1 each side, inner seal, shims, paper gasket, oil seal with container then hub. I didn't have the backing plate or retainer, what are the part no's for these parts ?
Old Apr 18, 2020 | 05:54 PM
midge's Avatar
hi this is Midge i have taken the rear hubs apart and removed the rear half shafts , the wheel bearing kit i purchased came with two bearings , two large oil seals which go into the retaining plate and it also came with two smaller oil seals but for the love of good i can not work out where they go , if some could advise me i would be so grateful , kind regards.
Old Apr 19, 2020 | 03:35 AM
CaptainQ's Avatar
Hi,
I recall there only being one on each side - when the parts manual refer to '2" they mean on the axle as a whole (they quote 10 wheel nuts but NOT on each side). Regards Keith
Ponysnake
Aug 27, 2019 01:40 PM
dpoznan
E type ( XK-E )
Jul 9, 2018 09:38 AM
eurolat
Feb 12, 2018 03:35 AM
Hemisfear
Sep 7, 2017 09:42 AM
David N. Warner
Mar 30, 2014 01:00 PM
