MK2, front lowering?
Old Jul 19, 2015 | 08:54 PM
blurooster's Avatar
Scale guy out of state at race, no scales yet. RH spring is 14.5" overall length, 5.5" outside diameter, 4" ID. Lower control arm at level with cross member is 9.5"= 5" compression at ride height.
5.5"x9.5 springs are available in any spring weight. I will take the spring to the race shop and get it checked. More later.....
Old Jul 21, 2015 | 12:47 PM
blurooster's Avatar
springs removed, safely with no spring compressor, cut to 11.5" and easily re-installed.
lower control arms are level with the weight on them. Scales arrived and will get the numbers on here tonight.
a/c compressor not mounted, rh seat not mounted, no water, no a/c unit and condenser/ fan in trunk, no exhaust and tailpipes only headers.
Old Jul 21, 2015 | 02:26 PM
MK2's Avatar
MK2
Default mK2, front lowering?
Okay, I will bite. How did you remove the springs without a spring compressor?
Lin
Old Jul 21, 2015 | 05:57 PM
blurooster's Avatar
With me(220) in it: 1601 front, 1598 rear, bias was almost 50/50 and 50/50 side to side.
2764 without me and fuel weight .My Camaro is3150 with me and fuel load.
Old Jul 22, 2015 | 06:55 AM
blurooster's Avatar
Car up on jack stands with tires removed; removed lower shock bolts(4), floor jack under a arm, remove spring plate bolts(6), lower floor jack and then remove upper shock bolt. Lowering the jack and removing the upper shock bolt is accomplished together.
The front corners were around 800# a 5 1/2 x 11 850# spring will be sourced and installed. When I cut the coils they got softer not firmer. Usually the other way around.
Old Jul 24, 2015 | 06:37 AM
blurooster's Avatar
Called Eaton Spring and got a"BOOK" guy, nothing listed for Jaguar? Do you have 5.5"x12" 375# springs? The "BOOK" lists by make....
I have figured a way around my problem with minimal $ and work that will maintain my ride.
Old Sep 22, 2018 | 01:29 AM
J11ames's Avatar
Default Solution for lowering Mk2 after engine swap.
Originally Posted by blurooster
Any proven suggestions on lowering the ride height of my 1962 MK2.
My engine swap removed a lot of weight off the front end and it needs at least 3" down to get back to normal height. I am considering cutting coils and dropping the base. Does anyone have the spring stats for stock? PSI, height and circumference? THANKS
My mechanics are almost complete and I am anxious to start the body work
get a bigger girlfriend.
H20boy
Dec 24, 2024 03:23 PM
Wolfy
May 28, 2024 08:06 AM
pnwrs2000
Jan 15, 2018 07:20 PM
ym37tech
Feb 8, 2016 01:04 PM
Jay48
Sep 7, 2015 09:30 PM
