MKII Rubber Steering Coupler
Old Feb 4, 2017 | 10:20 AM
tedwone's Avatar
Default MKII Rubber Steering Coupler
I'm in the process of rebuilding the lower steering column on my 1960 MKII and when I attempted to install the new rubber coupling I discovered the hole pattern is wider on the new coupler compared with the old coupler. The new unit spacing is 2 1/8" center to center and the old unit spacing is about 1 15/16", just enough of a difference that I can't use the new one. I can't find any source that supplies the size I need. Has anyone else had this problem or have recommendations for the correct replacement? When I removed the old coupler, it literally crumbled to pieces. Any information will be greatly appreciated.
Ted
Old Feb 4, 2017 | 10:26 AM
TilleyJon's Avatar
What is the part number of the replacement part you have?
Old Feb 4, 2017 | 12:08 PM
tedwone's Avatar
Default Rubber Steering Coupling
The part number for the coupling I ordered is 150696.
Old Feb 4, 2017 | 02:22 PM
TilleyJon's Avatar
I've checked the parts catalogue and that is the correct part number for LHD and RHD models, I will check the dimensions of mine tomorrow and get back to you
Old Feb 4, 2017 | 04:44 PM
Fraser Mitchell's Avatar
Later steering columns didn't use this coupler and had a totally different arrangement that is probably more robust. You could try finding one of these. The SNG Barratt website shows the two types. They list the rubber-type coupling as well at a reasonable price.
https://www.jaguarforums.com/forum/n...te=1&p=1614546
SNG Barratt - The Ultimate Jaguar Parts Specialist
You'll see that the upper column is the same throughout, only the lower column and coupling was changed. I had the later type on my 1967 Mark 2, and it could be the same as on the S-type and the 420, but not the 420G
