Not Sure where to ask this - AJ16 into MK2 question
Subscribe
Sep 5, 2016 | 04:45 PM
not the most correct place to ask this, but hoping someone will know, or can set me off in the right direction.
I Know an AJ16 4.0L is a variant of the earlier AJ6 design, But how interchangable is the flywheel, clutch and transmission with the earlier AJ6?
and with the XK even?
I have a line on an AJ16 engine, but it would be a hassle getting the wiring loom and everything else, and I would like to do a dumb (no computers) automatic, or possibly a 5 speed trans.
It might be too much to ask, but I have a rebuilt original auto box and torque converter that came with the load of parts when I bought my 3 mk2's. if I could use this, that would be ideal.
any advise?
Reply 0
Sep 6, 2016 | 06:17 AM
There is no commonality at all between the XK and AJ engines and transmissions. If you want to connect a Mark 2 gearbox up to an AJ16 engine, then extensive engineering work will be necessary.
Reply 0
Sep 6, 2016 | 06:51 PM
too bad, thanks though
Reply 0
Sep 7, 2016 | 11:56 AM
there could be a box out there that's fits,
I have a 4.2 v8 and no manual gear box made for it,but I have a speed box that fits know mods,and made a flywheel for it,
Reply 0
Sep 13, 2016 | 07:39 PM
Even so, you could still use a more modern trans and "adjust" the driveshaft instead.
Reply 0
Subscribe
Currently Active Users (1)
