power steering belt squeal
when steering under strain ie when stationary the power steering belt slips and squeals , I have tried tightening but still I get the same problem. I have tried some belt spray which temporarily helps but it is very annoying. I have been told to upgrade to an electrical unit but its £1400 for the parts alone!...
any ideas...
any ideas...
nah the first thing I did was check the tension , then I changed the belt making sure it was the correct one , the next thing was a tried a couple of other belts , the belt spray has been the only thing that has helped , but its very temporary.
someone has mentioned a spring loaded tensioner than might be sticking, I will have a look for that........
no fix yet....
no fix yet....
How is the belt sitting in the pulleys. The pulley "V" does actually wear over time, and the belt sits further into the V and it is this that can cause the squeal, as despite tension the belt bottoms on the V so there is no grip.
well thanks for the feedback , I traced it to a crack on the alternator mount right at the bolt. when I removed it , it simply fell apart but was really hard to see at first.
so a new mount , belts tightened and silence when I steer , phew at last!....
1964Daimler
Sep 9, 2015 11:28 AM
