Rebuilt engine won’t start
Old Apr 1, 2026 | 01:57 AM
  #61
cat_as_trophy's Avatar
Yes, my Better Half winced whenever asked to flick out the valve stem collets while I depressed the springs manually. Hey, I only slipped on odd occasions!
Then, fast and furious competition taught me I could bounce them out with a careful blow on a socket (box spanner?)
SWMBO really threw up objections when faced with putting the collets back in . . . I had to call on my sons!
Cheers and best wishes,
Old Apr 1, 2026 | 03:04 AM
  #62
timsdad's Avatar
This is the first time I've heard of another blacksmith bouncing valve collets out with a plug socket, I discovered this trick when a teenager many years ago and mostly do it in secret. The only damage I've ever done is burring up the plug socket I've mostly used. And maybe a couple of lost collets that esaped into that secret place under the bench where the trolls live.
Ray
Old Apr 21, 2026 | 08:02 AM
  #63
Lord_P's Avatar
Veteran: Navy
Veteran: Army
Curiosity got the better of me, after reassembling the distributor, I static timed the engine.
then I pressed the button…. And she started, 1st time!!
but…. Only for a few seconds.
now she starts intermittently, again only for a second or two…
couple of times I got her to run a little longer, and revved her then she died.
theres no vacuum line fitted so I blocked off the tube on the carb.
also my tachometer (rev counter) doesn’t work.
suspect either the spade terminals are corroded or the generator is dead, the latter being the worse news I could get due to the location.
any tips?
Old Apr 21, 2026 | 09:34 AM
  #64
timsdad's Avatar
You just need to check through it methodically, easiest things first - fuel pump working, float chambers full, connections on coil, inside distributor, etc. You need to find oiut if it's fuel or electrics but it's usually a problem with the last thing we messed around with. It might be an idea to hang a test light on the coil alongside the live feed, just in case it's a bad connection on a fuse or wherever.
Ray
Old Apr 21, 2026 | 10:06 AM
  #65
Lord_P's Avatar
Veteran: Navy
Veteran: Army
Ray
Last thing I messed with was the "everything"
Everything is scavenged or new, all cobbled together in a frankenstien engine.
Have spark, have fuel, new Coil. - is wired to the feed wire, + is wired to the distributor (is this correct?).
New floats, new needles and jets.
Idle screws set to 3 turns as that seems to be where it starts most successfully.
Are there any other adjustment screws? mixture? etc?
T I A
Old Apr 21, 2026 | 10:13 AM
  #66
Felixbobcat's Avatar
Congratulations! Must be a huge relief to finally get it running. Sounds like a possible fuel delivery problem. To check the Tach you'll need to get the engine running long enough to get a reading from a volt meter at the Tach generator. You can remove it to check but you're right it's a pain. The manual has a good section on how to check it.
Old Apr 21, 2026 | 10:25 AM
  #67
T I A
If your car is negative ground than you have the coil wired correctly. If your car has HD6 carburetors the air mixture screw is by the bottom of the carburetor where the float bowl attaches.
Old Apr 21, 2026 | 10:28 AM
  #68
Lord_P's Avatar
Veteran: Navy
Veteran: Army
NGL - was a tad emotional, someone was cutting onions.
  #69
Lord_P's Avatar
Veteran: Navy
Veteran: Army
Joy, accessible from the top? Will go look at a diagram..
Old Apr 21, 2026 | 10:31 AM
  #70
Check in your manual on how to initially set the air mixture screw. You have to remove the carburetor piston and suction pot to set it. If it is not set correct both carburetors could be out of balance. One rich and one lean or both too much in either direction.
Old Apr 21, 2026 | 10:34 AM
  #71
Lord_P's Avatar
Veteran: Navy
Veteran: Army
OK, so its the mixture screw I was messing with - #15 in this diagram...
Visible from the top, one on each carb...
SU HD6 Diagram
SU HD6 Diagram
So how does one adjust idle?
Old Apr 21, 2026 | 10:36 AM
  #72
BTW. Do one carburetor at a time. You don't want to mix up the pistons and suction pots. They are machined to fit the carburetor they are on, they can't be swapped.
Old Apr 21, 2026 | 10:41 AM
  #73
I believe number 15 is the idle speed screw in your diagram. I'm not seeing the air mixture screw!
Old Apr 21, 2026 | 10:51 AM
  #74
The air mixture screw is mounted on the collar I circled. It raises and lowers the jet bearing number 13 in the picture
Old Apr 21, 2026 | 11:17 AM
  #75
Lord_P's Avatar
Veteran: Navy
Veteran: Army
Yeah having watched "living with a classic" videos on YouTube, the Moss Diagram is definately wrong.
Problem is all the videos i watched need the car to be running to do any adjustment.
Back to the drawing board I guess.
One last question - static timing - at 10 Degrees BTDC or at 0 degrees DTC?
I did at 10 BTDC
Wondering if my timing is the issue still?
Old Apr 21, 2026 | 11:34 AM
  #76
Timing depends on which compression ratio your engine has. 7 to 1 is zero BTDC. 8 to 1 is 7 degrees BTDC. 9 to 1 is 5 degrees BTDC
Old Apr 21, 2026 | 11:36 AM
  #77
Those are for an S Type engine. I think the MK2 has different timing
Old Apr 21, 2026 | 12:45 PM
  #78
If timing is off it would run rough or the idle would increase. Did you rebuild the carburetors? They can be tough to put back together properly especially centering the jet. If it is off the piston won't operate properly causing it to drag. Also I would disconnect the fuel line at the filter and turn on the key to see iff you get a steady stream of fuel. If it stops then there is a problem with fuel pumps
Old Apr 21, 2026 | 12:51 PM
  #79
Lord_P's Avatar
Veteran: Navy
Veteran: Army
rebuilt with a service kit, initially the float height was off on the rear so it was flooding. Brand new (old stock) fuel pump, brand new fuel pickup line and filters.
9:1 compression motor - out of 2 Mk II’s but can’t verify. (Block was in when I got it, head from a barn find Mk II)
new plastic floats, needles and jets. Etc
Rex Moore
Nov 26, 2020 09:03 AM
avt007
Nov 1, 2015 06:45 PM
GT42R
Jul 6, 2012 06:44 PM
monkamah
Aug 29, 2008 06:23 AM
