Recommended transmission fluid MKII standard
Old Sep 8, 2014 | 05:15 PM
Norgards Automotive's Avatar
Default Recommended transmission fluid MKII standard
Any one know of the top of their head the recommended weight on the fluid for a 66 MKII standard trans with overdrive?
Old Sep 9, 2014 | 06:15 AM
Jose's Avatar
Correction: the manual transmission uses 30 weight OIL, not fluid. (not 90 weight).
another poster from Australia said Penrite Gb30 oil
90 weight is for the differential and steering wheel box.
Old Sep 9, 2014 | 04:18 PM
JPG's Avatar
JPG
Engine oil and EP oil (Extreme Pressure) do not have comparable weight ratings. A 30W engine oil is actually equivalent to a 90EP oil in viscosity. The difference between the two comes from the extreme pressure additives that could harm some brass or copper components in your gearbox. I my 1964 Alfa Romeo gearbox, which uses brass synchro rings, I do use 30W oil for that reason, as the old 90w gear oil recommended by Alfa Romeo is no longer available.
JP
1960 3.8 l Mk2 Auto
aholbro1
Dec 29, 2024 06:46 PM
Jandreu
Jun 30, 2022 03:10 PM
Dimitrigregorio
17
Sep 5, 2019 03:47 AM
1LowCat
Feb 23, 2016 07:19 AM
chatmanx
Sep 11, 2015 07:17 PM
