restoring/reforming console and armrest substructures
Old Feb 18, 2019 | 06:02 PM
jagstuart's Avatar
Default restoring/reforming console and armrest substructures
https://www.jaguarforums.com/forum/m...-208598/page2/
i was reading glyn's resto post (above) and saw he had the armrests fabricated in ABS (pg. 25). fyi, i took my warped pressboard/cardboard ones and the center console piece, got them a bit wet under very hot faucet, wiped off the excess and pressed them between pre-cut to match 1/2 pine boards. held with a set of wood workers clamps. after a couple of days (arizona, no humidity) they dried and were pretty much good as new.
Old Feb 20, 2019 | 01:47 PM
Jose's Avatar
Stu,
I have restored upholstery by gluing collapsed hardura / yute to chipboard and placing them between two plywood panels and then placing concrete blocks over the sandwich to flatten them.
also used WAX PAPER under and over the pieces so they don't stick to the boards.
Though I didn't have to wet the parts, that is how I fixed the Hardura-Yute insulation which was factory-glued to the metal panel behind the rear seat at the boot. The Vinyl-Yute becomes wrinkled as it collapses under its own weight as the glue ages. Happens to every S type.
I made a sandwich using a thin board cut the same shape as the vinyl and yute, then pressed the heck out of them for 2 days. Now it is flat and "tailored".
Old Feb 21, 2019 | 08:11 AM
jagstuart's Avatar
more work. guess i'll take a look at mine. unfortunately it's behind the a/c evaporator. IT WILL NEVER END!!!
Old Feb 21, 2019 | 08:52 AM
Jose's Avatar
if it is behind the a/c evap, I wouldn't bother. To do what I did you need total access to the boot to move around.
BTW, the XJ-6 trunk / boot is similar to the S type. I did the same thing to the back panel.
Old Feb 21, 2019 | 10:30 PM
jagstuart's Avatar
is that your SIII? don't know if you've seen this car. sold it to a true believer who is modifying the electronics. i still miss it.
'75 XJ12C, period air effects kit
african bubinga veneer, 4 spd w/laycock OD, XJS seats, a&b bank temp gauges
electric fan, crane ignition, KN filters
Old Feb 22, 2019 | 05:28 AM
Jose's Avatar
mine is a 1984 Series 3.. That car looks fantastic. you made a mistake selling it.
moonpetal38
May 4, 2012 06:24 AM
Andy94SC
Mar 8, 2011 07:52 PM
Andy94SC
Mar 8, 2011 05:55 PM
wolvesfan
Mar 23, 2010 07:35 AM
scottishjohn
XJ40 ( XJ81 )
Aug 16, 2009 06:37 PM
