S-type 3.8 1966, "drive shaft and flange" worn, looking for replacement
Old Dec 29, 2017 | 03:25 PM
Karl V's Avatar
Default S-type 3.8 1966, "drive shaft and flange" worn, looking for replacement
Hello!
I´m in the process of fixing up a 1966 S3.8 for trip this summer. What started as a "minimum effort" rebuild has avalanched completely and the front and rear suspension is disassembled, cleaned, painted and all bushings and bearings replaced. Brakes is upgraded to ventilated front and rear...
We pulled the output shafts from the differential and noticed that the splines on the left driveshaft was badly worn. Half of the thicknes of the splines was gone!
Is this a common problem? the right side looks good, I suspect the driveshaft wasn´t hardened properly
I have been looking at sngbarrat for a new driveshaft but they list it as no longer available. Ebay searches didn´t find any either.
Àny help in finding a replacement or tips how to repair it is very welcome. I would rather not weld on material and the machine new splines, it could be possible but then it would probably need to be hardened again.. lot of work with potential screw ups.
Karl
Attached Thumbnails S-type 3.8 1966, "drive shaft and flange" worn, looking for replacement-20171229_164240.jpg   S-type 3.8 1966, "drive shaft and flange" worn, looking for replacement-20171229_164351.jpg   S-type 3.8 1966, "drive shaft and flange" worn, looking for replacement-drive-flange-4hu-005-8.png
Old Dec 29, 2017 | 03:47 PM
Robman25's Avatar
I am guessing that there are no dedicated Jaguar wreckers in the country? I am guessing you are in a Scandinavian country? If so then something in the UK should be able to supply?
Old Dec 29, 2017 | 04:01 PM
Karl V's Avatar
Yep, living in Sweden. Probably not any specialist jaguar wreckers, not common in Sweden with specialist wreckers for classic cars. Not enough classic cars to wreck if it isn´t a volvo..
I will see if I can find a wrecker in UK, I order most of my parts from UK since it is much cheaper than Sweden.
Old Dec 29, 2017 | 05:15 PM
Robman25's Avatar
But that would be slim pickings wouldn’t it? I didn’t think Volvos died
Old Dec 29, 2017 | 05:31 PM
Fraser Mitchell's Avatar
You'll probably find its common to the XJ/XJS saloons diffs from 1968 onwards. Worth a check, anyway as there is a lot more of the stuff around for these cars. The rear suspension changed not at all until 1986 !
Doug Dwyer may know.
Old Dec 30, 2017 | 01:39 AM
TilleyJon's Avatar
Fraser may be right, found these https://www.ebay.co.uk/itm/JAGUAR-XJ...gAAOSwiBJaPmc6
Old Dec 30, 2017 | 02:35 AM
Robman25's Avatar
I think you will find they are unique to the ’S’ /420 you would need to check the rear track width.
Old Dec 30, 2017 | 04:24 AM
No, I don't think so, any track difference was done by varying drive shaft length. However, one never knows until one has the two parts side by side.
Old Dec 30, 2017 | 04:48 AM
Karl V's Avatar
Well they put salt on roads here to melt away the ice in the winters and salt makes the cars rust really bad. So many old cars is scrapt due to rust, engines will run forever if oil is changed now and then. And of course quite a few rwd volvos is lost every winter during drifting exercises in the roundabouts..
Thanks for all the replies! I will try to get some measurements or get hold of a XJ6 outputshaft to compare.
Is anyone keen on disassemble thier diff just to take a look?
Old Dec 30, 2017 | 06:46 AM
TilleyJon's Avatar
Try contacting the guy from eBay to see if he can give you the dimensions for the XJS ones he has, the same part fits the e-type etc, and the Salisbury HU axle was a very common unit, so there is a good chance it will be the same across all makes/models, the drive shafts would be different as Fraser says IMO.
Old Dec 30, 2017 | 07:22 AM
Homersimpson's Avatar
How about this, maybe they would ship it?
https://www.ebay.co.uk/itm/JAGUAR-Di...IAAOSwFbJZ44fi
Old Dec 30, 2017 | 09:25 AM
TilleyJon's Avatar
The guys in the first post I put re eBay sale are Simply Performance Jaguar Specialists, family run business, I am sure if you call them they will help and confirm if the XJS/XJ6 E-Type Salisbury re diff is the same as the S-type/420, their number is +44 (0) 1306 711134 , then you will know if either those or the diff in Hopersimpsons post will an option.
Old Dec 31, 2017 | 09:16 AM
Simply_Performance's Avatar
If you need more information on the shafts that are on our eBay shop let me know.
I am happy to give you all the dimensions that you need. I think they may be different as the earlier shafts changed. We should have some early shafts in stock if the ones we have on eBay do not fit.
Thanks,
Ben from Simply Performance
Old Dec 31, 2017 | 11:51 AM
TilleyJon's Avatar
Nice one Ben, thanks for that. Hopefully Karl will be in touch and you can sort him out.
Do you generally get much Mk2 stuff ?
Old Dec 31, 2017 | 05:03 PM
Robman25's Avatar
Correct, I was thinking of the Drive shaft not the output shafts
Old Jan 2, 2018 | 02:36 AM
Karl V's Avatar
Thanks for all the helpfull answers, I appreciate that alot! I have been up north in Sweden and been skiing for the last few days that´s why I haven´t answered.
Thanks,
Thanks! I will take measurements tonight and contact you. I will put the measurements here also so anyone else who needs the information can find it.
Happy New Year!
Karl
Old Jan 2, 2018 | 10:30 AM
TilleyJon's Avatar
Hopefully you get this sorted, happy new year to you and all too Karl
Old Jan 3, 2018 | 04:21 AM
Karl V's Avatar
Here are some measurements on the output shaft. I hope it i enough to check if there are any major differences.
Karl
Attached Thumbnails S-type 3.8 1966, "drive shaft and flange" worn, looking for replacement-output-shaft-measurements-1.jpg   S-type 3.8 1966, "drive shaft and flange" worn, looking for replacement-output-shaft-measurements-2.jpg
Old Jan 3, 2018 | 06:00 AM
Karl
Nice work! I will have to dismantle a shaft to get the dimensions. Let me check and get back to you.
Thanks,
Ben
Old Jan 4, 2018 | 08:24 AM
vaultsman's Avatar
Worth an email to Alan Slawson at AJS Engineering. I reckon. Alan rebuilt my Powr-Lok diff last year and had to replace one of the output shafts with a good used one from his stock.
He might or might not be willing to part with one as his stock must depleting, but I'm sure he'd give you some info on commonality if you can supply the diff serial number.
AJS Engineering Services - Jaguar specialists
Good Luck!
Stan
