Spare tire fittment
Old Jan 6, 2019 | 10:31 AM
csbush's Avatar
Default Spare tire fittment
Lesson learned the hard way on fitting a spare tire. I had a spare wheel sitting around but since it looked like it had been used as a boat anchor I had it sand blasted and powder coated. Went to a local tire place and got a tire that matched what I had put on the car. Bad move. As you can see from the photo the 185s are much wider so that the mounting bolt will not reach to mount the tire in the holder and the cover will not fit down over it. I did have an ancient spare that came with the cars in 165 width, and fortunately it was still pliable enough to remove from one wheel and mount on the newly painted rim. So it worked out nicely.
185 vs 165 width
“New” spare
It fits!
Old Jan 6, 2019 | 11:02 AM
Coventry Foundation's Avatar
CS what 185 did you buy. We have seen the problem before with wider tires but not 185. Normally if the tire is too thick to use the hold down the lid will also not fit. Interesting.
Old Jan 7, 2019 | 04:05 PM
Jose's Avatar
find a donut, it opens up space. After all, a spare is for an emergency.
Old Jan 12, 2019 | 07:53 AM
Homersimpson's Avatar
I have 185/80/15 on my car and it fits a treat in the spare wheel well.
165 sounds a bit narrow for a MK2.
Old Jan 12, 2019 | 01:01 PM
JeffR1's Avatar
And not tall enough, they're meant for a Volkswagen Beatle.
I was running a set if these and it just looks to small, the car sat too low to the ground.
jackra_1
26
Apr 18, 2020 09:33 PM
romello424
Mar 16, 2016 02:01 AM
wesmc2
Nov 27, 2012 10:24 AM
Clifsmith
Oct 12, 2009 03:28 AM
